Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Trying to install mbr-2310, getting error313: multiple wired adapters dected. I checked control panel and found only one connected. I'm trying to install to charter high speed, my connection is IEEE
  • 49 Answers
Dont use the CD setup. Call your equipment manufaturer of your router for manual configuration on your mbr-2310.
Posted on Jan 04, 2009
My netbook tells me to reset my wireless adapters Im trying to get wireless internet. It tells me there a network to connect to but it won't let me connet to it.
Hi
For uninstall the driver of Wireless adapters follow the mention below instruction.
  • Go to the control panel and click the Add & Remove program.
  • You see the install driver list you have to select the your wireless adapters and click the remove.
  • After few min you driver is uninstall the window show you driver uninstalling finish.
  • Then reboot you computer.
  • After rebooting you get New hardware found window in start up the notebook,take the wireless driver installation CD and put the notebook CD-ROM.
  • And new hardware found window click next, automatic he install the driver in CD, after complete the driver installation reboot you laptop once more.
  • Now you wireless adapter connect to Internet and your problem will solve.
If my answer solve you problem then give me 4 thum
Thanks
Aug 24, 2011 | Acer Aspire One D255 Netbook
Trying to get wireless
there are some options that might help u: 1. check to see whether wireless adapter is on; 2. if wireless adapter is on, check on drivers whether wireless driver is installed (check in device manager in control panel); 3. check your network connection, check the connection is "disabled". If yes, right-click to enable it. 4. if the above is not your issues, then try this: right-click the wireless network connection to check the available wireless networks, select one of the network, type WEP key and connect it straight away.
Nov 20, 2010 | Computers & Internet
Lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 13, 2010 | Lenovo IdeaPad Y430-3231U Notebook
Multiple network adapters found
Go to Start->Control Panel->Network and Internet->Network and Sharing center->Manage network connections
You will find icons like local area connection, wireless connection and lot more. Just have one local area connection enabled and disable all other icons. Then run the setup
Nov 01, 2009 | Belkin (F5D5231-4) Router
How to connect multiple phones to voip adapter? Only line 1 is available for connection.
Have you tried using a 5 or 8 port switch to see if this will allow u to have 8 or 5 more phones available ...they do make a 25 switch if you want to add 25 phones
Sep 18, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Wireless adapter for computer to link to a D-Link WEB-2310 rout
you can buy a usb wify adapter at wally world also knpwn as walmart. just plug it in and run disk and your connected
Sep 07, 2009 | D-Link AirPlus G DWL-G510 802.11g/b...
Ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
Jun 02, 2009 | NetGear WGR614 Wireless Router
Error 313
Network connection showed 3 LAN or High-Speed Internet connections. One said it was disabled, another one had a big red X over it, and the last one said connected. The big red X, though unplugged, was apparently still active. The fix was as simple as disabling it.
Apr 09, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Linksys WPC54GS wireless adapter installation issue
There's a possibility that the adapter is defective. However, you may still try the following:
1. Make sure to uninstall the software if you still have it installed. Remove it from the Programs list or under Add/Remove Programs.
2. Check Device Manager and make sure adapter is not under Network Adapters nor Other Devices. It might be called Network Controller if driver is not installed correctly.
3. Unplug card, shutdown computer and when PC is powered off, plug card back and restart computer.You may insert the CD on this process, but do not run/continue the CD setup wizard.
4. When computer is back on, you should get a Found New Hardware bubble message or wizard.
Just finish the wizard and tell me how it went. Goodluck!
Jul 08, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
141 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
