Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Lost key for my other pc's
Hi, I have a Belkin 2.4 ghz -802.11g, I lost the key for another laptop that I would like to install. Also lost the manual so forgot how to get into the router info area.
how do I get into the router configuration area? And is there a way to find out from my computer what the key is ??/
thank you
  • 104 Answers
To access your router configuration page, type the router’s IP address into a web browser.
I think this is 192.168.2.1 for the Belkin model. Note there is no ‘www’.
(If this does not work, and you’re using Windows, go to Start > (Run) and type cmd in the box. Click OK, to pull up a command line window. Type ipconfig into the window, and press return. In the output that appears, the Default Gateway shows the router address.)
You should then see a screen requesting a password. If you have not changed this, press return, because the default is blank (no password).
When you have logged in, go to 'Security' under the 'Wireless' menu. You should see your passkey there.
Hope this helps. Please come back to Fixya if it doesn’t work or you need further help.
If you want to download a manual, there are some on the UK site
here:
Good luck...:)
Posted on Dec 24, 2008
Just hooked up the router to my pc and put in the install disc that came with it, the Belkin program won't open on my computer and the laptop I'm using shows it as an available wireless connection put...
Welcome to Fixya. If you want to connect to the Belkin Router Wirelessly and it is asking you for a Security Key, all you need to do is to access the router settings page and look for the Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless and look for the Security Key or Network Key (Passphrase)
Thanks for using Fixya.
Mar 04, 2011 | Belkin Basic Wireless Router
I have lost my cd to install for my belkin router what shall i do ?
Hi i got your issue
no problem if you lost the installion Cd
Step 1: Contact belkin customer support 18002235546 and select IVR option 5 4 2....they will give You a free cd
Step 2: Or contact belkin technical support 18002235546 and they will assist in installing the router witout the cd
Thank you:
Priya
Oct 02, 2010 | Belkin Wireless-G Plus MIMO Router
Lost "Samsung Update Plus"
Do a system restore back before you installed the update. Contact Panasonic about this problem, they might have a solution for you.
Mar 14, 2010 | Panasonic Toughbook 52 - Core 2 Duo P8600...
Hi, the laptop will not boot up. no operating system found
Put in Windows CD to see if it picks it up, go to install screen to see if it will start to install, if it does then it is finding your HDD. Try the repair option then. Your windows may just be corrupted.
Also try hitting F8 for other options, e.g. Safe mode to remove corrupted drivers.
Mar 13, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi its saying bluetooth licence key not found and bluetooth stack not found
download the the bluetooth drivers for you laptop thru the manufacturer's website.
Feb 14, 2010 | HP Pavilion DV2500T 14.1" NOTEBOOK LAPTOP...
Belkin N 150 slow connection with MACs only & PCs are fine.
I had the same problem.
My solution was related to the fact that I had configured my router for OpenDNS.
Once I added those DNS servers to the DNS tab in System Preferences on my macbook Pro, the speed problem disappeared.
Hope this helps you, as well.
Jul 13, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Belkin router
I'm guessing that your laptops are using a wireless connection. If this is the case the first time you enter the wireless security key (password) it will be stored in the laptop so you don't need to enter it again.
To connect to the router, you need to open its associated web page which you will normally find by typing the routers IP address into the address bar in Internet Explorer. The usual default address for a Belkin router is 192.168.2.1.
Once you connect to the router you should be able to access all the security settings from the Belkins main menu.
Sep 11, 2008 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Main PC can't connect but others can!
I had this model of router quite some time ago. I had some bad experiences where when I tried to login to it I was unable to, the web based management interface would not respond (as you have described) . Resetting the device would resolve this I would recommend trying that. Unplug it, wait a few minuets and plug it back in. Then try again to access the management interface. 192.168.1.1 or 192.168.0.1 or whatever via a web browser.
Apr 30, 2008 | Belkin (F5D7633UK4A) Wireless Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
