Question about RCA DIRECTV Satellite Remote Control
I got this universal rca remote for 6 devices and do not remember
Help
  • RCA Master
  • 5,568 Answers
There ain't no such thing as a 'universal' remote. All of them are 'multibrand' and none of them cover every device ever built. You might check RCA's website to see if they have expanded the code list for your model of remote.
Posted on Dec 23, 2008
I need the code for an Insignia TV, so I may program my RCA remote.
Try 1020 for an Insignia TV. Most RCA universal remote codes can be found at http://www.rcaaudiovideo.com/remotecodefinder/ . Use the drop-down menus to select your remote and then the type of device that you want to have the remote control.
Please note that the codes in an universal remote control are usually limited to those for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a newer remote.
I hope this helps.
Jun 24, 2011 | RCA RCR460 Remote Control
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
Wanna know the code for a emerson tv
Which universal remote are you trying to program? The codes will vary by manufacturer (RCA, One-For-All, etc). Most of the universal remotes manufacturers have support sites for their remotes with either code lists or code finders available. For RCA remotes, start here: http://rcaaudiovideo.com/remotecodefinder/ and enter the model of the remote and the device type. Then look for the brand of your device.
Some devices are made by another manufacturer and the code for the company that built the unit may work if the brand of the device isn't listed.
Please note that universal remote codes are limited to those for devices released more than 6 months before the remote was programmed. If your device is newer than the remote, you may need a new remote.
I hope this helps.
May 12, 2011 | Televison & Video
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
Tip
I hope that helps.
on Apr 06, 2010 | RCA RCR311B Remote Control
I have a rca remote controle and i need the code for hitachi tv
I tried to include any info you might need. The first of which are the Hitachi TV codes. The first list is for the 6-Device RCA remote pictured with your post. Since there are a few different 6-Device models I also included a list of those.
Below that are three links. The first is for the manual for the 6-Device RCA remote model #RCR6473N. Next is the codes for the same model.
Finally (just in case that's not your model), a link to RCA remote control support page.
Sorry I couldn't get you the kitchen sink. ":}
Hope this helps.
11643, 11145, 10145, 10056, 10096.
009, 011, 027, 036, 037
http://audiovox2.info/docs/rca_acc/man/RCR6473N_DOC_OM.PDF
http://audiovox2.info/docs/rca_acc/man/RCR6473N_DOC_OTHER.PDF
http://66.77.167.109/rcaaccessories/RcaaccessoriesController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_UNIVERSAL_REMOTES
Nov 19, 2009 | RCA 6-Device Universal Remote
Help
Hi
The code for Sanyo TV from a Phillips Universal Remote is 0181.
If 0181 doesn't work,try 0506. I have a Sanyo tv and hopefully that'll work for you.
Try one of these
017,021,039,056,057,058,
0154, 1907
Check this website also
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
Sep 19, 2008 | RCA 3-Device Universal Remote
RCA DIRECTV Satellite Remote Control Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
