Question about Ricoh CL3000E Laser Printer
Vertical streak near left edge of printouts....only affects black portion of print image
Prints from our CL3000e have started to exhibit a vertical streak. or smudge like line near the left side....toward the left edge of the prints, but a little bit inside of the far left edge....no on the very edge....maybe between 1/2-inch and 1-inch indented from the left margin. I've read the manual and tried all maintenance options available, and checked the toner carts, as well as the "waste" toner container..all look okay. There are also no maintenance messages indicating the need to replace the photo conductor unit for either the color or B&W. I was wondering if this streak might be an indication that I need a new BLACK PHOTO CONDUCTOR UNIT TYPE 125 FOR CL3000. They are $79 on-line, but I don't think we've printed close to the number of copies indicated in the duty cycle for this part...so wondering if there's some "cleaning" function I could perform to clear up this problem, rather than buying parts and swapping to see if that fixes the problem. The printer only gets light to moderate use and is only about 2 years old. We have the duplexer option installed...but this streak is present on single-sided copies as well, so I don't think that's a factor. Any help/suggestions would be appreciated. -- Jimbo
  • 1 more comment
  • Jim Bartlett Apr 12, 2007
    Any advice on where to find service manuals or other instructions on how to locate and clean the parts you mention (charging wires, LED array)? I've found nothing on this so far, and a call to Ricoh left me empty-handed as well.
    Also, I experienced a paper jap not long before (perhaps immediately prior to) the onset of these streaking symptoms. Is it possible that something (paper bits) got left behind when we cleared the jam? Where would I look for the guilty bits of crud?
    Thanks in advance for any further wisdom and advice you're able to share. -- Jim
  • Jim Bartlett Apr 13, 2007
    Thanks! I'll take a look inside!
  • Jim Bartlett Sep 16, 2007
    Thanks everyone. Couldn't find the LED array or charger wires, so decided to just replace the photoconductor units....it's been several years since we bought the unit and multiple sets of toner cartridges have run through the printer...so I decided it was reasonable to now replace the PCUs. Problem fixed in about 2 minutes... and more than a few $$$. Been working fine again now for several months.
Get a new printer. I have replaced the photoconductors - both black and color - every 5000 pages or so. I am replacing the printer.
Posted on Sep 16, 2007
  • 247 Answers
Where best to look will depend a little on the nature of the smudge. If what you're looking at is white, then you might just have a little heap of toner or paper dust on part of the LED array that paints the picture onto the photoconductor drum (look for a narrow unit that stretches full width, adjacent to the drum. Dark marks may, if you're lucky, be down to dirt on charger wires. Both respond well to cleaning with a vacuum and a soft cloth (be very gentle if cleaning the wires). I would be inclined to trust the existing photoconductor unit unless you know it's been abused (e.g. by leaving it lying around in daylight) or the coating on the drum is visibly damaged. A.
Posted on Apr 11, 2007
  • Alastair Macleod
    Alastair Macleod Apr 13, 2007
    You can find manuals athttp://www.ricoh-usa.com/downloads/manua...
    Best guess is that LED array will probably be in the printer body, facing into the slot you slide the photoconductor unit out of.
    Charger wires may be visible within the same slot, but are quite likely to be part of the photoconductor unit itself.
    A.
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Vertical streaks but only on first 2-3 pages
replace the image units associated with the color of the streaks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 17, 2017 | Konica Minolta Magicolor 4690MF...
I have been having trouble printing my red. My letterhead contains a red "A" in it and a few other items have red. Normally, the red items have pink, yellow or white vertical streaks through...
Replace the magenta image unit. Yellow image unit also and for the white streaks have the glass that cover the laser cleaned.
Jul 29, 2011 | Brother HL4040CDN Duplex Unit
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Black streaks down left side of printouts Epson Aculaser C2600
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Dec 02, 2008 | Office Equipment & Supplies
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
cartridge).
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Ricoh CL3000E Laser Printer Logo
712 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Inky Fingers
Inky Fingers
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
