Question about Refrigerators
GE Refrigerator - Freezer is not working.
I have GE GSS22WGPE WW. We do not use ice maker, so it is switched off but we use freezer section. Today When I took out Ice Cream box from freezer section, it was watery instead of solid. I also noticed ice crystals on the inside wall of the freezer section. Using air dryer I removed all the frozen ice crystals from wall and put the freezer to maximum cold. After 8 hours ice cream is still watery and ice crystals start building up on the wall. Is this something I can fix by myself or I have to contact service technician?
Thanks,
Jayakumar.
  • tkamprath Jan 03, 2009
    I have the same problem.
    The freezer is not holding the cold temperature, ice crystals forming in the back.
    I manually defrosted the freezer by leaving the door open with it empty for 3 hours.
    Started refrigerator back up and it worked fine for a couple of weeks. Then the same problem occured again.
    I suspect the defrost is not working. Looked fot the defrost timer but only found a printed circuit board.
    Can anyone help in fixing this or do I just need to call for service.
  • 173 Answers
SOURCE: Freezer temperature will not get cold enough
Clean cooling coils. Check refrigerant level.
Posted on Jul 08, 2009
aborcass
  • 2651 Answers
SOURCE: Freezer doesn't keep ice cream frozen
not being able to keep ice cream is not good, before doing anything ck a few things. make sur e to pull out unit and vaccuum under and behind unit, if it cant breath it cant freeze. check in back by compressor, is the fan running to cool the fan??? if the compressor is on so should the fan be. next id look behind the freezer wall for excessive build up of frost( it might even be buildin up with ice throughthte back wall, inwhich case you have a defrost issue
Posted on Apr 02, 2008
docjohn174
  • 943 Answers
SOURCE: ice cream is not frozen
hi thanks for the question try turning the thermostat to a higher number
Posted on Sep 25, 2008
  • 103 Answers
SOURCE: my ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
Posted on Jun 01, 2009
tborn6
  • 700 Answers
SOURCE: Freezer-Ice forms on food in the freezer and ice
check the door gasket to see if theres any tears or if its dirty, also check the coil on the back to see if theres any dirt on it if so it needs to be cleaned.
Posted on Jul 02, 2009
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Ice maker has water but no ice
HI.TERRY.freezer has to work at its optimum.for the ice maker to work. i would try to defrost the freezer completely first and try.good luck.Ali
Jun 28, 2012 | Samsung Refrigerator Ice Maker -...
Refrigerator freezes items in the rear and there is frozen water on the bottom of the freezer section directly underneath the ice maker
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | GE Profile Arctica Stainless Steel Top...
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GSS23WSTA refrigerator freezer section is getting warm.
Just the fist indication that defrost is not taking place. Most likely the defrost heater and defrost thermostat will need replaced. part number Click Here=> WR51X10101 for heater and will be easy to spot if burned out and you should also replace the defrost thermostat just in case part number Click here=> WR50X10068 Let me know if you need assistance, you may reach me through Appliance 911 or Sea Breeze Appliance Parts and Technical Services
Thank, Sea Breeze
Dec 25, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
GE refriferator cooler side is warm/warming
possible cause the fan motor that takes air from the frezer section may not be working or seizing up check to see if your fan is working after seting your dial at corect numbers thans from gilles
Mar 15, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Refrigerators Logo
362 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
