Question about HP Photosmart C3180 All-In-One InkJet Printer
Hp C4250 all in one does not align photos on photo paper
If I print to the HP C42450 using printer paper the top 1/4 inch of the image is missing. If I use plain paper image comes out fine. If I print four 5x7 prints on two pages and have a page of plain paper and a page of photo paper the plain paper prints correctly the photo paper is missing the top 1/4 inch.
I have updated the drivers and spent several hours online with HP tech support. But have made no progress. Anybody got any suggestions.
Running Windows Vista on HP PC
SOURCE: HP PSC 2210 Vista prints part of page
Call HP tech support - they walked me through an easy work-around that solved this problem for me.
Posted on May 09, 2008
mspcrepair
  • 169 Answers
SOURCE: hp psc 1210 not working in vista - but diagnostic utility shows all ok - and prints test page
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
sodeep
  • 3267 Answers
SOURCE: how to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Posted on Mar 22, 2009
bob_computer
  • 3153 Answers
SOURCE: HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
Posted on Aug 23, 2009
MUKHTAR
  • 2022 Answers
SOURCE: HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Sep 08, 2009
I replaced the cartridge for my HP C4250 printer/scanner but the alignment page did not print properly, so I did not get a proper scan page. Now it will not print at all. What next?
A cleaning will fix the problem. To clean your HP C4250 > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc etc...
hope this helps, thanks!
Sep 30, 2011 | HP Photosmart C4250 Multifunction Photo...
Tip
HOW TO GET THE BEST DIGITAL PRINTS...
Printing a photo but not getting it upto your expectation.....?? No worries just fiddle a little bit
with the printing options and keep in mind some important points that I am going to tell you....it will help:
1) RESOLUTION OF THE IMAGE TO BE PRINTED... Always keep in mind while printing a digital
printout that the resolution should be best fitted i.e. of the original photo.... if you stretch A photo too
much or squeeze you might not get the desired result. It depends upon the DPI i.e
dots per inch that appear on the paper in the snap that you print. To get a quality print you must
make sure to select proper dpi for an image in printing. Eg. for printing a snap of 300 dpi you must choose
the image resolution as 600 dpi, but in case of professionally required image quality you can select upto 24oo dpi.
2) PRINTING PAPER ... Make sure that the paper you are using is suitable for the ink and the printer that
you are using. Certain printers specially design Photo Paper suitable for the ink used in them for eg. HP printers
do have Hp photo papers to give a good quality of image.
3) SETTINGS IN THE PRINTER... You can adjust the image quality that you want by clicking on the
Properties Option in the printer dialog box that opens when you give a print command. for eg. you can select
Economy mode for saving the ink (but this will not give a good quality image as colors to will be low),
or you can use the Bes option, as suitable for you...
So next time you Print a photo or snap of yourself make sure to remember these points and have fun.....
Good Luck!!
on Apr 08, 2010 | Office Equipment & Supplies
Trying to print a 4 x 6 photo with HP Photosmart 130 I'm trying to print a 4 x 6 photo with HP Photosmart 130 printer, from my desktop HP Photo & Imaging software. It prints all but last 1/2...
It is for sure a matter of settings ..so you have to select the paper type ..and the dimensions ..and also the position ...landscape or portrait ...and after that go for the print..Also select the paper type and size in the printer if it has the feature for it ...It is safer to select there too ..cause from computer you have to make it each time and you may miss something ..
If it is still making problems ..just reinstall the printer 's driver and software from scratch ./..(remove the old one ..and reinstall a clean version of the software ) This way you will be sure it is not an software error..
Aug 02, 2011 | HP PhotoSmart 130 InkJet Printer
Efforts to print 4x6 borderless print result in only top part of photo paper being used and top third of photo being cut off
First thing to try (and I'm assuming you're attempting to print a photo within HP Image Zone & have already selected the 4x6 photo tray? Hint: can be done via printer, properties, printing shortcuts) is to change the 'more options' directly below where you'd selected the 4x6 image size and then change to 'shrink to fit' vs. the default 'crop to fit'... Additional thoughts includes rotating the image (can be done directly on the preview screen...)
Dec 18, 2010 | HP Photosmart 3310 Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Paper jam with card stock paper
Try Getting a PM kit to replace all the rollers.
Nov 13, 2008 | HP LaserJet 2550Ln Printer
Alignment of photo paper
Borderless printing up to 8.5 x 24-inch using brochure and photo paper.
Are you using this specific paper? If so, it may be that the paper sensor is not detecting the paper edge properly. Does the printer act as if it is printing in the blank area?
May 06, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
189 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
