Question about BMI Computers & Internet
My DVD duplicator is not burning DVD's.
We have a BMI 4x DVD-RW Duplicator. It has 5 slave drives and the master drive. We use it on a weekly basis and last week it worked fine. Today, I tried to insert a DVD for it to copy to the other drives, but it says that there is a problem with the target drives. The DVD that I am burning from is a DVD+RW. I am trying to burn to DVD-R. The power is working, but anything that I try says the target drives are not working. I have tried doing each slave drive individually, but none of them work. What can I do to get them to work?
    Master:
  • BMI Master
  • 534 Answers
Try in this order:
  • Check cable connections.
  • Reinstall drivers.
  • Try different brand of DVD media.
  • Replace drive.
Posted on May 08, 2017
  • 1019 Answers
SOURCE: Replacing drives on Vinpower CD Duplicator
Can,t see why not.
any ide drive should be compatable, i,d reccomend a Pioneer 112D. great drive reads and writes virtually Anything.
Mike @ compurepair.
Posted on Apr 04, 2008
SOURCE: Targer drive not ready.
I know I get the same error when I try to copy a cd and I accidentely leave a dvd in one of the target drives. So make sure that when you copy a cd that you have cd-r's in the drive and when you copy dvd's that you have dvd'-r's in the drives. Or it could be something else. Just a thought.
Posted on Jul 25, 2008
SOURCE: teac 1x1 dvd duplicator dvw-d11
target drive not ready. what am I not doing right? it is a 1x1 dvd duplicator, teac. also had target overflow message what size dvd should I be using? new machine, copies cd great.
Posted on Oct 15, 2008
  • 3600 Answers
SOURCE: acard 1 to 3 duplicator can't seemto get past the traget disc not ready
of course theres a problem but what are you doing with the thing? are you formaating the disk first to render the dvds in the target drives? are you using the right DVD like DVD+ DVD+- or Blueray? need more information to help you. and it the DVD you are copying has been redered on another machine it won't copy it anyway. You have to use the same machine to copy it as thats how they protect copy rights now days.
Posted on May 29, 2009
Crankstart
  • 696 Answers
SOURCE: Trying to burn dvd. It keeps saying Target drive not ready
Hi, assuming the rest of the drives are working there are three probable issues.
1. The cabling for power or data is loose or faulty, check the cabling, remove and reseat it, then try again with new data cable and swap power connectors with one of the other drives. If the results do not vary it's not the cables, If the problem moves with the data cable but is not resolved by replacing the cable it is the logic board at fault.
2. Try cleaning the drive, do not use brush cleaners as they can damage the head, just used a compressed gas can or air compressor on less than 20lbs/in, if this does not work...
3. The second drive may be faulty, check with the manufacturer/manual. Many of these devices require a specific model or one of only a few models for compatibility, replac with an appropriate model.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
I have a stand alone dvd/cd duplicator at our church having trouble with. Cant copy onto dvd-r's. Master can be dvd-r or dvd-rw and will copy onto dvd-rw. when i try to copy onto dvd-r's, it will run for...
The two common problems, copier doesn't like color of discs etc, and slowing the speed that leave you've already tried. After those the most likely thing is that one of them has heads that are out of alignment. You could try copying cd's as they have coarser and the heads don't have to be as accurate. If that works then it is very likely it's the heads out of alignment. If they won't record on the cds at all it still can be the heads out of alignment too, but this test may help determine which drive is out of alignment.
Mar 06, 2011 | Computers & Internet
The error message "Target drive not ready" indicates that there is a problem with the blank disc inside the writer drive(s) of the duplicator. In order to solve this problem, please insert brand-new blank media into the writer drive(s) and press the ENT/OK button twice on the duplicator. If you are still having problems, please feel free to contact us @ 888-686-8868 x208. Thank you for your inquiry and thank you for purchasing EZ Dupe products.
EZ Dupe Technical Support
Jan 09, 2011 | EZ Dupe EZDupe CoolCopyD5 DVD 1 to 5...
How much does it cost for the 1 to 3 duplicator
Probably a *LOT* more than just using your correct CD-writing software to tell it to burn '3' copies, serially, rather than using a Plextor Dupsonic to burn '3' simultaneous copies.
Probably, a *LOT* more than "outsourcing" your disk-copying needs,
e.g., http://www.wimmedia.com/duplication-replication.php (Western Imperal Magnetics has good rates for many-at-a-time duplication).
Jan 05, 2011 | Plextor Dupsonic 52X 1 to 3 CD Duplicator...
I have a Pioneer CD/DVD Duplicator 8 drives. Recently no matter what disc I put in as the master. It tells me I have a mad Master Disc. Obviously all the media can't be bad. When this messgae pops...
The 3rd drive is the master now. If you want to change back to top drive, go to #8 "select source" and use up/down key change to " drive 1 " and save. for more detail, please read the user manual page 21 and 22.
For VPD system,if the top drive defected, the system should auto assign 2nd drive as source, but your system pick up 3rd drive as source drive, I suggest you check drive 1 and 2 before make copy.
Jan 04, 2011 | Pioneer 1 to 7 DVD Duplicator: SharkCopier...
The controller only burns to 4 out of 5 drives and 1 of the 4 working frive keeps making burn errors. Is it time to install new firmware to fix this? or do i have to install new drives? Can i install...
Hi I have this problem with my systor 0-3 target duplicator, the one tray works fine, the middle one keeps making burn errors and the bottom one won't burn at all I can't seem to find a solution
Sep 20, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
Cannot copy dvds or cds with my duplicator
Hey! Usually, DVDs have some protections which prevent DVD users copying DVDs freely. Theser protections include CSS protection, region code protection etc. Therefore, you need to remove DVD protections first if you want to copy DVDs. There are some DVD Copy software which can do this. I have a good luck with this DVD Copy which works fine. You can have a try if you like.
Hope that helps.
Nov 07, 2009 | Plextor Dupsonic 52X 1 to 9 CD Duplicator...
DVD duplicator
I contacted EZ Dupe directly. They were very helpfull & recommended the proper drives.
Sep 15, 2009 | EZ Dupe EZDupe CoolCopyD5 DVD 1 to 5...
Clip on back of drive?
CS: cable selector
SL: slave
MA; master
if ur installing this drive as a main drive put it in master if justa secondary drive put it in slave
if ur ide cable ve one more room for one drive it will select automaticly slave or drive
rate me as fix ya!!XD
Aug 19, 2008 | Apple Genuine Pioneer "SuperDrive"...
Accutower duplicator
accutower won't burn cd it says "no clear cd'
Apr 08, 2008 | Tower ACCUTOWER CD "Music" 5 Writer...
Computers & Internet Logo
93 people viewed this question
Top BMI Computers & Internet Experts
David Payne
David Payne
Are you a BMI Computer and Internet Expert? Answer questions, earn points and help others
