Question about NetGear WG111 802.11g/b Wireless Adapter
Netgear wireless adapter
Hello I have a wireless router and 4 computers 2 being laptops which have wireless and 2 homebases bothe homebases have a netgear adapter installed. 1 works fine and stays connected the other keeps disconnecting and having problems i have search the internet for a solution and i think it might be because both home bases are using the same channel is this correct
    President:
  • 2,961 Answers
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Posted on Apr 11, 2007
  • andrew pester
    andrew pester Apr 11, 2007
    The only time you need to change the channel is if you are getting interference from other appliances for example microwave ovens.
SOURCE:
Netgear adapter/router compat. issue
1. Unplug the router for 1 minute
2. Clear the browser cookies, temp folders,history.
3. reboot the computer.
4. Ping the router
5. log into the router and check the status page.
May 20, 2010 | NetGear WNR2000 Wireless Router
Laptop is showing my network
Hello write 1tune2,
1. Using a computer wired to the router, please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. For security reasons, the router has its own username and password. When prompted, please type in admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network.
a. Switch for the wireless adapter is turned off.
b. Distance between the wireless router and computer.
c. Possible wireless interferences.
Feb 12, 2009 | NetGear RangeMax WPN824 Router
Netgear DG834G V4 Website connection problems
Please try to use a difrent DNS service.
For example open DNS:
Primary: 208.67.222.222
Secundary: 208.67.220.220
Jan 14, 2009 | NetGear DG834G Router
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Dec 06, 2008 | Computers & Internet
In this case can you please tell me what is your wireless router and how may computer do you have so we can check if this is a problem with the wireless router or with the netgear wireless adapter. because if you only have 1 wireless computer so the problem here is with the wireless router we may need to change some wireless settings like the wireless channel .....
Nov 15, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Cannot connect to my laptop with a built in wireless.
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
I have a netgear wg111v3 adaptor and a netgear wireless router. both setup fine and get on net ok. but when i turn my computer off then on again i have to re install my wireless adaptor. can u help?
hello!
-- try to install the adapter to a diff slot/ port
-- try to uninstall the driver and use updated driver downloaded from the netgear website to reinstall the driver
-- unistall old driver or other adapter on the computer to avoid driver conflict
May 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NETGEAR WIRELESS
More details are needed here, do you have mac address filtering on and is your router using dhcp or fixed address for your computers?
Jan 17, 2008 | NetGear WGR614 Wireless Router
NetGear WG111 802.11g/b Wireless Adapter Logo
245 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
