It is possible that your shaver does not turn on or move because it is dirty. There can be hair or dirt particles stuck inside it, causing the shaving heads to be blocked. To fix this problem, properly clean your shaver. If possible, remove the shaving head and clean your shaver from the inside as well.
Shaving head check indication
After two years of use the red shaving unit symbol
î will flash for 30 seconds during 7 shaves to
indicate that you should check the condition of the
shaving heads. This indication is based on an average
shaving time of 3 minutes per shave. When the
shaving head symbol flashes, all other symbols and
lights are out. When the shaver is switched off, the
shaving unit symbol disappears.
When the red shaving unit symbol starts flashing,
you should check the shaving heads for possible
damage. If the shaving heads are damaged in any way,
they must be replaced in order to obtain optimal
shaving results
