Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer top load Wont spin
Everything else works. But in the tub inside is wobbley and wont spin
  •  Sherman
    Sherman May 11, 2010
    when you put your washer lid down do you hear a clicking noise
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Nut comes loose on bottom. Turn washer on side and re tighten. Happened to me twice. Used locktite the second time.
Its the large nut on the bottom of the washer basket. Can't miss it.
Posted on Dec 02, 2015
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Posted on Dec 27, 2008
Washer wont spin
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite top load washer was rinning perfect til it got dropped 8 inches during a move now the whole tub seems loose and it wont balance when the spin cycle is on Help
Your support plate under tub above gearcase was knocked out of place, lean washer back and try to adjust plate back in place were it is sitting back on the glides. This is not an easy task bu it can be done,sometimes it is best to call a repairman to do the repair so he can check if there is any more damage.
Dec 22, 2009 | Kenmore Washing Machines
Kenmore Elite King Capacity wont agitate or spin
Following is the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20952992
Following is the Whirlpool / Kenmore installation and maintenance PDF for top load, direct drive washers. It includes troubleshooting and testing sections for both the motor and capacitor.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 06, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Was getting the f 51 code, now d 5 code. its a kenmore elite oasis canyon top load washer.
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
187 people viewed this question
Sal De
fordexpert
Robert Rankin
