Equium 100 will not resume from hibernation. Neither battery nor AC indicators illuminate unless battery is removed, AC connected and battery re-installed. Battery shows [and should be] fully charged. When pressing power on button various keyboard lights flash but no boot up and both power indicators go out.
  • 4,806 Answers
Hi there
Sounds like the motherboard is faulty if all you get is led flashing on and off. Try it on AC power only, if it boots there is a problem with the battery, if it does not its most certainly the motherboard.
I do take it this is a laptop and not a desktop
Regards
Posted on Dec 23, 2008
    Sergeant:
    Novelist:
  • 327 Answers
If u have spare battery insert that and check out.
How do i test the power button on a toshiba equium l40 laptop
OpenControl Panel, Power settings, Advanced Power settings, change SLEEP to Never, Hibernate to never. Shut down and unplug, if you use mostly on AC, remove battery, your laptop when not in use. It will last longer, if there is a power surge not be damaged, and a reboot every day resets the computer.
Dec 26, 2012 | Computers & Internet
Iwas dusting and cleaning my acer one note book and then said goin into hibernation . now it will not go back on .
Usually you must press power button, but if not back on try to remove battery and try after 30 sec to power on again.
Mar 31, 2011 | Acer Aspire One PC Notebook
Every time I turn it on, it displays nothing, just a black screen.But the power indicator is on and there are some white lights flashing next on the Caps lock button and above the scroll button..
Dead (ish) Laptop.
Press the power button momentarily to check if it is hibernating or in stand by. If this doesn't work;
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine and the laptop still won't start, then you may have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Feb 04, 2011 | Computers & Internet
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
My toshiba laptop windows vista will not start.when u nturn it on it goes straight to a back screen..
  1. Check ur powercord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
Aug 20, 2010 | Compaq Presario Notebook
My Acer Aspire One went into hibernate mode by itself and am unable to turn it back on unless I remove the battery and use it solely on electricity mode. Please help.
keep press power button for 1 mins and your laptop will turn off. when you turn on your laptop. disable hibernate mode.
to return to your desktop from hibernate mode press power button quickly. windows will resume
May 04, 2010 | Acer Aspire One PC Notebook
Armada E500 notebook Power button not responding.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery.
Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf
How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration by launching the Power Management applet as described above. On the Battery Calibration tab, all installed batteries will be displayed in the primary list box. Next to each battery name will be an indication of whether calibration is required for that battery. If calibration is necessary, the phrase “Needs Calibration” will be displayed. Select the battery to be calibrated, and click the Start Calibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate that calibration is in progress. Each phase of calibration (charging or discharging) will also be displayed. Calibration is complete when the icon is no longer displayed in the System Tray. Battery calibration requires several hours for completion. If you choose to continue using the computer during the calibration process, it must be connected to AC power. The calibration process must be allowed to finish without interruption. Performing any of the following actions will prematurely terminate calibration:  Clicking the Stop Calibrating button in the Compaq Power tab.  Unplugging AC power from the computer.  Unplugging the calibrating battery. (This action may result in data loss if a second battery is not installed.)  Undocking the computer.  Pressing the power or standby button.  Powering down or suspending the machine by using the Windows menu. IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You must restart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY To calibrate a battery on computers without the battery calibration utility, complete the following steps: 1. Remove the second battery, if present, so that only the battery needing calibration remains in the computer. 2. Dock the computer or connect the computer to AC power. 3. Turn on the computer. 4. Check the current battery capacity level by positioning the cursor over the battery icon in the system tray. 5. Allow the battery to charge to 100%. You may use the computer, but the recharging process will require more time. 6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT). 7. Undock the computer or disconnect the computer from AC power. 8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the Computer in MS-DOS Mode > OK. 9. Allow the computer to discharge until it shuts off. 10. Dock the computer or reconnect AC power. 11. Allow the computer to charge again to 100% as in Step 5.
Feb 19, 2010 | Compaq Armada E500 Notebook
Sleep State Resume Trouble
Yes, unplug, remove battery, replace, then start. It's just glitched slightly, no biggie.
Aug 09, 2008 | Dell Latitude D600 Notebook
Compaq presario c700 notebook
Disconnect the AC Adaptor, Take the battery out, press and hold the power button for 7 seconds. Put the battery back in. Connect AC adaptor. Turn the computer on. If issue persist, restart and get into Advanced Boot Option by clicking on F8 Key and choose "Last Known Good Configuration" option. If issue persists please post for further help.
Good Luck
Jan 20, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
14 people viewed this question
Alun Cox
David Payne
David Payne
