Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 80 Leaks when filling and leaks when spinning
If I stop the water going in, the water will just go through the holes at the bottom of the basket. Then it goes all over the floor. When the washer spins, the water also goes all over the floor.
  • 179 Answers
Sounds to me like you have a hole in your pump
Posted on Dec 23, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
My kenmore 80 series washer will not stop filling up with water at the start of the cycle.
check the clear plastic line going to the pressure switch inside the console,blow into it to see if there is a hole in it or it could have slipped off the pressure switch, or you have a bad pressure switch,blow gently into the switch you should hear a click but it still could be bad,the pressure switch is what shuts the water down when it's filling and if there's a hole in the line or any air leaking out of the clear hose the water will not stop
Jan 30, 2010 | Kenmore Washing Machines
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Dec 13, 2008 | Kenmore 24832 Top Load Washer
Water after spin cycle
remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Nov 05, 2008 | Kenmore 24902 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
156 people viewed this question
Sal De
fordexpert
Robert Rankin
