My windows media player won't sync with my mp3 player
Media player will not let me configure sync settings and when i try to sync with the mp3 player it copies half of a song and then aborts the whole thing. it says sync is complete but there are no songs on it. or it says that there are aborted files and cannot sync. every time it is a new problem and i cant fix it. the mp3 player will sync to my moms media player but it won't mine
  • 10 more comments
  • Anonymous Jan 09, 2009
    my sync tab doe not have al the options. How do I fix
  • Anonymous Jan 29, 2009
    my computer just doesn't do anything when i plug it in to a WORKING usp plug in.
  • kiama Feb 25, 2009
    My WMP was functioning OK but now it's having a hissy fit and refuses to sync. When I hit the sync tab, it invites me to create a playlist but it also has up the top the request to insert a device. This despite the fact that my MP3 player is plugged in to the USB port.
    So when I have created a playlist the "Start Sync" tab will not activate.
    Other functions such as play and burn are OK.
    Can anyone help me..............please?
  • Anonymous Mar 19, 2009
    Windows media player will not sync music to my mp3? when i click "finish" where it asks you if you want to sync it manually or automatically i have clicked "finish" on both options. but once I try to sync somthing, it says that "Windows Media Player has encountered a problem sync-ing the files to your device" !!!!!!!What do i do?!!!?!!! I have found no answer from anybody or anything?!!!!!!!!
  • MikeNbran262 Apr 07, 2009
    I was able to sync just a few days ago and now it is not recognizing either player that I have. I have switched USB cords and it still isn't working.. I think it's a virus.
  • Anonymous Apr 07, 2009
    i have the same problem as guest on March 19 ... !! anyonee With help ??
  • bambampiff36 Apr 25, 2009
    i put the files i want on to the sync list and start the sync then it start to sync like it usually do but then says a error
  • agksoccer28 Apr 28, 2009
    when i plugg in my sansa it dosent sync and says its in the usb hood and i cant acces that from MY COMPUTER and when i plug in my phillips it works fine what am i supposed to do.??
  • drunkdriver5 May 03, 2009
    my windows media playe wont sync i put music in list pane and click start but it says connect device so it wont sync music what wrong?
  • Anonymous May 08, 2009
    it use to sync until i erased all the songs but when i triedto put some new ones on there it wouldn't sync
  • cruzie_bby May 18, 2009
    i have dhe same problem..
    my device is plugged nd wen i ty 2 sync my songs, it says it worked but then i cnt find them on my device...?
    wat happened..?
    it worked b4 i updated dhe windows media player....?
  • arthurmatini
    arthurmatini Oct 21, 2012
    Mine doesnt say anything , i tried inserting nd takin it bak out ......hellpp
    Master:
  • 350 Answers
Go to Run enter regsvr32 wmp.dll RUN AS ADMINISTRATOR if needed if the problem is there it should fix it.
Posted on Jan 27, 2011
Plug my player in it goes instantly to media player to transfer. Says it transfered songs but no where to be found on player?
You must have Windows Media Player configured to run automatically when your Clip is plugged in. This is OK, but unless you have the Clip configured within WMP to actually have music synced to, no music will be synced to it.
When WMP runs, you should find your Sansa Clip in the vertical list on the left side. Right click on it and select "Set up sync", then follow the instructions from there.
Jan 26, 2010 | SanDisk Sansa Clip MP3 Player
I'm trying to add to my player. The player itself says it's connected but the Windows Media Player isn't recognizing that it is connected. The start Sync button is not reacting when I click on it. Problem?
I;ve notice if your computer is not configure properly, windows media player gives you very hard time syncing devices. You also, should check and see what version of windows media player you are using. 11 will sync properly with most devices.
Sep 08, 2009 | SanDisk Sansa m230 MP3 Player
Mp3 player
This player only works as the manual suggests if you use Windows Media Player 10. It is not compatible with iTunes. If you have Windows Media Player 11, there are detailed instructions on how to get it working right on GPX's website.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit - not from iTunes
1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
2. In Device Setup - Configure Sync, write a name for your mp3 player.
3. Click Finish. The window closes and the Sync feature in the Player is displayed.
4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
5. Select the songs or entire albums from the center pane.
6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
7. Click the Start Sync button on the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Dec 10, 2008 | GPX MW3836 MP3 Player
Cant add music to my player
Note: You will be able to download purchased/subscribed songs to the unit.
-Tha Mp3 Doctor
Dec 09, 2008 | GPX MW3836 MP3 Player
I HAVE WINDOWS VISTA
Nov 13, 2008 | GPX MW3836 MP3 Player
How can i see the songs on my mp3 player?
Uninstall the GPX software and then reinstall it - the new installation will take the new version of Media Player into account.
-Tha Mp3 Doctor
Nov 12, 2008 | GPX MW3836 MP3 Player
Have an mp3 player.. dont know what i am doing incorrect.
Windows Media Center is different than Windows Media Player - you will need to download some version of Windows Media Player to use this device properly.
-Tha Mp3 Doctor
Sep 21, 2008 | GPX MW3836 MP3 Player
Miranda
-Tha Mp3 Doctor
Aug 29, 2008 | GPX MW3836 MP3 Player
I have the MW3837
-Tha Mp3 Doctor
Aug 19, 2008 | GPX MW3836 MP3 Player
Help with syncing music to my comp frm my mp3
Generally, you can move music from Windows Media Player to yur mp3 player, but not the other way around. Press the sync button, and set up a sync profile for your mp3 player - then it should recognize the songs that are on there. If that fails, I would reformat the player inside of Windows Media Player to see if that helps any.
Have fun!
-Tha Mp3 Doctor
Jun 26, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
6,817 people viewed this question
 Grubhead
Grubhead
