Question about Lexmark JetPrinter Z25 InkJet Color Printer
Not able to activate printer to actualy print
I have checked the cables/ports. The printer does "click" in responce to the Print command, but no printing occurs.
    President:
  • 2,961 Answers
Assuming the driver is installed ok, when you have got up the window that says print does the Z25 printer show in the printer name box at the top of the printer, if not click on the drop down box and select the Z25. Also go to control panel>printers and faxes and see if your printer is there, and if so check that it is set at default by right clicking on the printer icon and select default and check that it is on line, if not click connect on same menu
Posted on Apr 11, 2007
My printer is not printing
Standard checks: If you are using Windows system up to Vista: Check all these:
Power cable, USB or LPT serial cable, the port to where you are printing in the printer properties configuration, (right click the printer icon) - (computers with multiple USB ports: unplug and plug into a different USB port and watch the printer icon change to ready in the computer/system/printers window- very subtle). Sometimes stored print commands from several days ago will begin printing.
Check cartridges, error light indications you can research on Google.
Jun 09, 2016 | Office Equipment & Supplies
I have hp laser jet 1020 printer., when i provide print command all commands are showing in different language which i can"t understand
Called "Junk Print"...Check USB cable, Check USB port dry solder mounted on printer mother board., remove & re-fix farmatter board.. If not solved replace formatter board. If ur technically sound replace USB port mounted on board..
See the image farmatter P/No: CB409-60001
Feb 27, 2015 | HP LaserJet 1020 Printer
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
It seems like the computer and printer are not communicating. I do all the moves on the PC but when I command "print" nothing . I've checked all the cables and even changed USB ports, still...
hi,
  • Is the printer properly installed?
  • Have you set it as your default printer?
  • On the start menu, click on printers and faxes.
  • Is the printer checked[ticked]? Right click on the printers icon and select properties.
  • Check the printers connections by clicking on ports.Had you used same ports connection?
  • If not set them right.
  • Click on print test page.
  • Restart your PC and try printing now.
Sep 16, 2011 | Lexmark Office Equipment & Supplies
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
Hp 1401 all in one will scan and print but will not print from computer command
check out the port u r using to print, follow the setup instructions to select the correct printer port.... if not, go to:
- Start - Control panel - printers - right click the printer u need - properties - ports..... check if it's on LPT1 or other and the printer is USB connected - try the diferent USB001, etc to find the correct port........
If this doesn't work: check out if printer is "use printer offline" and turn it online or paused....
If all this does not fix ur problem try chanching the usb cable.....
Jun 29, 2010 | Office Equipment & Supplies
My HP Laserjet 1020 printer does not give printout from a remote computer. Even the print command given by local host computer does not work. The print commands given earlier does not get deleted when...
First you clear the pending print job
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer. if still you fail to print follow this steps to troubleshoot the issue.
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP LaserJet 1020 Printer
Printer not comunicating with computer used disc all set up,try to print then told no conection it wont print,done all that was asked diconected reconected cables turned computer off then restarted still...
1.Change cables
2.check ports
3. update firmware
4. try on diffrent computer to rule out printer as a whole.
Not working still put that one in the trash and get another brand.
thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Lexmark C533DN InkJet Printer
Hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Jun 03, 2009 | HP PSC 1410 All-In-One InkJet Printer
New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Feb 24, 2009 | HP DeskJet 820Cse Printer
Lexmark JetPrinter Z25 InkJet Color Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
