Question about Rimage DiscLab DL5200 (555101120) Burner
Productionorderstatus_1_2.dtd not found
Hello My rimage dl5200 gives me the above error message along with "there are no servers currently processing orders" no jobs will go through the system any thoughts? thanks in advance dave
0 characters
1 Points
Rimage 3400 auto loader
R U sure the firmware update was the correct update and that it installed successfully? Check in the firmware part of the burning program to obtain a list of the currently installed firmware.
Apr 07, 2014 | Rimage Professional 3400 NSS CD/DVD...
Rimage 2000i is getting
Check its memory and i think it can solve the problem.
Performance Chip
Aug 28, 2012 | Rimage 2000i CDR 2 (52X), CD Duplicator...
I get the error "printer not found" - do I need to
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Jan 26, 2011 | Rimage Amigo II (555501201) CD-R Burner
Where can I replace the glass door on my rimage protege?
Hello latyboyd,
The Part# for the Protoge II is 501090-001.
I don't believe we stock that part anymore though so you might have to obtain one aftermarket.
Jan 09, 2011 | Rimage Producer 2000 Protege Burner
My Rimage 2000i will not begin production of cd burn/print. Says there are no production servers active on cluster
Hello B13Designs,
If you receive a "No Production Server Active" message when using QuickDisc, make sure that the Production Server status is set to Active, Processing orders in Rimage System Manager. Once the Production Server is set to this status, jobs can be processed.
1. Open Rimage System Manager.
2. Select Production Server. Production Server status information displays in the right panel, next to the Production Servericon.
3. If Production Server is paused or stopped, press the play button. Production Server starts.
If this does not fix your problem, feel free to give our support line a call @ 1-800-553-8312 (Option 2).
Nov 18, 2010 | Rimage 2000i (530101320) DVD±R Burner
Target line has no recorders: 103
Hello carl vicary ,
We at Rimage value you as a customer and are equally concerned when you are experiencing issues with your Rimage Unit. To better serve you, please call our Support Technicians at 1-800-553-8312 (Option 2) Monday through Friday 7:30 AM - 5:30 PM CST and we will be happy to further assist you.
Nov 16, 2010 | Rimage 2000i (530101320) DVD±R Burner
Executing OTP version 3.04
Hook a VGA monitor, keyboard and mouse up to it. Then turn it on to see if it's booting into Windows or even into the BIOS. If it's booting into Windows, then download your autoloader firmware from (click the support link, then your model, download the autoloader firmware) -- then unzip it somewhere on your Rimage and use Gemini Utilities to update the firmware in the autoloader. Then restart the computer and see if you still see the same message.
The printer being recognized is tied very closely to the autoloader firmware working. Also, it helps to make sure the printer's switch is set to the position marked for Transport.
Apr 15, 2010 | Rimage DiscLab DL5200 (555101120) Burner
Need software for rimage ras13 DVD/CD duplicator no printer
I have the software I can copy iy for you, I need to know how to us my computer as a production server that all that is keeping mine from working!
Jan 17, 2009 | Rimage Desktop 4500 DVD-R Burner
Rimage DiscLab DL5200 (555101120) Burner Logo
20 people viewed this question
Top Rimage CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Gareth Cockram
Gareth Cockram
Mike Carew
Are you a Rimage CD and DVD Burner Expert? Answer questions, earn points and help others
