Question about Dell Spacesaver USB Keyboard J4624 SK-8115 RT7D50
DELL KEYBOARDCAPS LOCK DOES NOT TOGLE
I cap lock is on it will lower only with the shift key
    Scholar:
  • 56 Answers
Hey there,
You are getting this problem cause of:
1. Dust resides on ur rubber pad of ur K/B.
2. Check controller button of ur K/B
open ur keyboard and checkout the rubber as well as the tacker of ur key button.
Remove the dust on the rubber as well as the circuit board.
Thanx.
Gimme ur acknowladge by rating me.
Romy
Posted on Dec 24, 2008
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
TURN OFF CAPS LOCK DELL SK-8185
Click on the Caps Lock button ;) if that wont work, then for lower case just use shift and the wanted letter
Aug 04, 2012 | Dell y530k - Slim Black Usb 104-key...
Cap lock is stuck on-- I need to use lower case to
Anyways, you can use the shift key to convert the password characters in lower case.
All you need to do is to press shift+your password.
Remember that you need to hold the shift key down while pressing all other keys to write in lower case.
Also, with your keyboard you may need to get help from a local repair.
Please do tell us that you have the problem fixed.
We are always available for your help.
Regards.
Jul 19, 2010 | Microsoft Windows XP Home Edition
My cap lock won't lock, however I can get a
Gently removed the CAP LOCK KEY and inspect for dirt or a broken retaining clip. If dirty blow it out. If the clip is broken the key will not work I'm afraid to tell you
Jul 17, 2010 | Dell Inspiron E1705 Notebook
Have a dell laptop but it doesnt start when i push the power key a little lock with the letter a inside blinks what does this mean then the computer shuts off by itself
That icon is the indicator for Caps Lock (aka Shift Lock). When in the operating system (Windows), you can turn the icon on (or should be able to) by pressing the CAPS Lock key, and turn it off by pressing the CAPS Lock key again.
Jun 29, 2010 | Dell Latitude D600 Notebook
I HAVE A LOCK WITH A NUMBER 1 ON AND CANNOT USE MY LOWER CASE KEYS> HOW DO I UNLOCK WHATEVER I HAVE LOCKED?
try pressing the caps lock key once, if still your caps lock key does not respond then possibly the key is stuck, try backing up your data first do a system restore when you think you can still use lower case on your keyboard then check if there will be changes, if still no changes occur, a long shot would be re imaging windows back to defaults again make sure you back up data first the then try again once windows is reinstalled if no changes then your keyboard works but the caps lock key is busted ^_^ I do not see any other option for the caps lock key to be troublshooted. ^_^
Jun 04, 2010 | Acer Computers & Internet
Caps lock key not working - held down the key for
Press shift key for at least five times and then release when you hear a peep sound, On the Keyboard tab, uncheck everything and click Ok, if this doesn't solve, then again press five times and uncheck everything and click Ok. I also like to know if you were typing on some program like Ms-Word when the problem occurred. is the caps lock led on? Please let me know so that I can help you better.
May 06, 2010 | Microsoft Windows XP Home Edition Service...
CAPS LOCK
Often you can depress the caps lock and shift key simultaneously, holding down for a few seconds and that will unlock the caps lock
Nov 06, 2007 | Logitech 967233 Keyboard
Computers & Internet Logo
129 people viewed this question
Clive
Clive
Alun Cox
