Question about RCA HD52W59 HDTV Projection Television
The picture on the tv is cut off
Everyones head is cut off on the tv.
    Genius:
  • 1,030 Answers
Using your remote push left or right arrow keys to change format
Posted on Dec 24, 2008
Why cant I get it off of wide screen? Everyone's head are cut off and can not read subtitles at bottom.
the aspect ratio is the picture size control
when you select aspect ratio you have to move with the arrows to get the size that fits the panel the best - go ok then exit to save the setting
if that doesn't work the the tv will need attention in a repair shop
Sep 03, 2015 | Televison & Video
Screen cuts off top of heads
Check the menu settings for the picture. You may be expanding the image to fill the sides, in the process, cutting the top and bottom.
Mar 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
Haze cloud picture that cut people head off...
the picture sounds like its blooming, you must turn down the screen control on the back of the fly-back transformer, or the transformer has gone defective more likely and needs replacing
Jan 27, 2010 | Televison & Video
I have an RCA D40W20 tv. I have the vcr/dvd connected to the video 1 jacks. picture will not format to screen. everyones heads are cut off. picture is too tall. any fix?
Ty using the zoom settings on the TV or the dvd player, also check the inputs by testing the tv with free to air or another input to determine if its the tv or the dvd player. Good Luck.
Nov 27, 2009 | RCA Scenium D40W20 40" Rear Projection...
The tops of everyones head is cut off the bottom and sides are also cut off
Check your manual and change your aspect ratio.
if thats not it check your controller board.
for more info/ detail make a new post with the make and model of your TV
For a used one check www.rns-systems.com
Oct 16, 2009 | Panasonic TH-42PX6U Plasma TV
I can't see the whole picture. the tops of everyone's heads are cut off. Normal, stretch, zoom format does not fix it
check to see if tv has a function call aspect ratio
that should take down the picture size not screen size
Aug 17, 2009 | RCA F32650 32" TV
TV picture doesn't fit in screen no matter what the setting
Ok, so I think I have your solution :)
You're actually my first when it comes to this site, so hopefully this fixes your problem!
Step 1 - Turn off the cable box, but leave the TV on
Step 2 - On the front of the 8300HD, press the "guide" button and the "info" button at the same time
Step 3 - Choose "HD" for High Definition, or "SD" for standard definition. (Sounds like you're HD?)
Step 4 - Choose the aspect ratio 16:9
Step 5 - Choose "progressive scan" if it asks you.
Now press the "power" button on the box, does that fix it?
Apr 03, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
TV picture is not good
from what your describing it sounds like a resolution or ratio setting on your t.v. you can change these setting on your cable box and t.v as well this seems to be the setting on your t.v. since you have already unhooked the cable box. if changing the settings doesnt resolve your issue you may have some failed components on the pc board that could be repaired by a repairman v/s purchasing a new one. hope this was helpful....
Dec 16, 2008 | Sylvania 6427TE 27" TV
I HAVE A SANYO, ON MY REMOTE CONTROL IS A BUTTON "PIX SHAPE" this will change the sides and top/bottom. I have 4 settings. OR you might check you owners manuel as to where this button is. Possibly under menu. My Dads TV is a little different from mine. so your button might not be where mine is.
Nov 23, 2008 | RCA HD52W59 HDTV Projection Television
Picture on TV
Your problem sounds like it could be a vertical sweep fault. Sounds like a vertical output IC or a capcitor in the sweep power supply or a waveshaper capacitor. All these faults, should only be checked and replaced by a pro tech, as there is a safety issue involved with the High voltage, and your going to need to know how to use the equipment to check these parts as in this case , you most likly wont be able to look and see whats wrong or what part is defective. Good Luck
Aug 12, 2006 | GE 46GW 948 46" Rear Projection Television
RCA HD52W59 HDTV Projection Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
