SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
SOURCE: Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
SOURCE: Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
SOURCE: Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
