Question about Onkyo HT-SR800 System
Blow right speaker channel - ONKYO TX-SR506
Recently a bought an ONKYO TX-SR506. I discover a problem with speaker cable in zone 2 but I made a short circuit connecting the right channel, thats because I left connected the other side of cables without speaker. Now all the right side of speakers (zone 1 and 2) are in mute. There is some way to change a protection (fuse?). I realy like this amplifier.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 36 Answers
There is some way to change a protection (fuse?). No. The fuse usually was not broken. How long did your amp turn on?
3 seconds (DC protect) OR immediately shut down (Over Current protect)? How to confirm?
1.Unplug the amp.
2.Remove the metal cover.
3.You will see a long vertically installed pre-amp board mounted next to those large power transistors fixed by 12 screws on a large aluminium heat sink.
4.Remove this long vertically installed board mounted by 2 screws.
5.With 2 screws removed, just pulling this board out and hold it with one hand.
6.Plug the amp and switch it on.
7.If your amp stays ON forever, the problem is from this long board.
8.If switch off at once, the problem is from power amp board.
Try the above- mentioned steps. I will tell you what to do next. Just search you tube for SR600 cap replacement. I have written an email here. Write an email to me if you want to fix this amp.
Blow right speaker channel - ONKYO TX-SR506 - 116ce2d4-ea32-4d12-b206-8d4fbc261e33.jpg
Posted on Oct 01, 2017
3 Suggested Answers
ebackhus
  • 31 Answers
SOURCE: 3 speakers dont work
Check to make sure that Speaker B is not pushed. It's on the front panel on the bottom left.
Posted on Jan 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: What are the correct connections to connect a
Depends what you're trying to do with two amplifiers. Fill in the intent piece.
Posted on Apr 14, 2011
I have and onkyo tx sr-506 receiver and it has no sound on zone 1 , but zone 2 works normally . what can it be ? where do i look for ?
Hi Leonardo, I am sorry about your issue. I suggested taking it to a service center. Thank you. Onkyo USA
Sep 14, 2016 | Onkyo Audio Players & Recorders
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Outdoor speakers on Zone 2
Hello Fixya customer,
Thank you for your question.
Please verify that Zone II power is "Acitvated" from the Hardware menu.
Thank you for using Fixya, an let me know if you have any additional questions.
May 01, 2010 | Onkyo TX-SR605 Receiver
I have an onkyo tx-sr506 and the system shuts off as I turn up the volume. It doesn't get very loud (barely audible) before shutting off.
Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
Mar 15, 2010 | Onkyo TX-SR506 Receiver
I have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Nov 04, 2009 | Onkyo TX-SR506 Receiver
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
TX-SR506 Bi-Amping
If you select bi-amping the device will use a second amp for your rear speakers, this indicates that in your setup menu you probably have deleted the rears (set to None). Try to find the settings for your rear speaker in your setupmenu and see if they are selected in normal operation.
If all fails, see if you can reset teh device back to factory settings, sometimes software can get confused after using for a while. Resetting should than fix most problems.
You can also check and see if there is maybe a software update available for your device, loading and installing is explained in either the file or on manufacturers site.
Sep 15, 2008 | Onkyo TX-SR506 Receiver
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
Onkyo HT-SR800 System Logo
135 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
