Question about Kicker CVR12 Car Subwoofer
How to wire a kicker 15 cvr
I have 2 kicker 15's that was hooked up an i took it out an now do not know how to wire them back up can anybody tell me how to do it i am hooking them up to a kicker zx350.2 am they are 4ohms speakers
  • 15,935 Answers
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Your amplifier is not stable @ 2 ohm bridged. So you will have to wire them independantly on each channel.
+/- on sub to +/- on L channel
+/- on sub to +/- on R channel
Wiring the subwoofers in paallel will result in a 2 ohm load, which your amplifier is not rated to do. Doing so will cause heat buildup, and damage to the amplifier.
Posted on Dec 24, 2008
  • blueextc3221
    blueextc3221 Dec 24, 2008
    If you wish to run the amplifier @ 2 ohm mono (bridged), to wire the subs in parallel, put + to both subs on L+ terminal at amplifier, and - to both subs on R- terminal at amplifier.
    It may be loud for a few minutes, or a few days, but wiring in this fashion will harm the amplifier.
    BE WARNED
How you hook up 15 inch kicker cvr show diagram please
Here are a few wiring diagrams to get your started.
Oct 01, 2010 | Kicker Car Audio & Video
I have a 15 cvr how do i hook it up to a plnet
If it has only one set of terminals on the sub just plug and play- if it has dual coils wire them in parallel(+ to+ and - to -) and wire them to the amp
Feb 12, 2010 | Kicker CVR12 Car Subwoofer
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
How do you hook up 2 15 inch cvr to 1 ohm
Hello juanelreypla,
If your CVR's have dual 2 ohm voice coils, they can only be wired for 0.5 ohm, 2 ohm, or 8 ohm final loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
If they have dual 4 ohm voice coils, they can be wired to a final load of 1 ohm. Wire the voice coils in parallel and then parallel both subs. Like the diagram in Wiring Option #1 shown here.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4
Nov 10, 2009 | Kicker CVR12 Car Subwoofer
I have 2 alpine r type 12's hooked up to a kicker crossover and a NRG 2200 800 watt amp. they are wired series and parallel. when i turn it up the subs sound like the are fluttering. what is going on.
well my friend either your amp is not powerful enough to push your subs or you have a sub that is shorting out cause i just had the same problem with my 2 15 kicker cvr competition subs
Nov 04, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
I have 2 12 in kicker cvr tryna drop to lower ohm
http://www.colomar.com/Shavano/dvc_spkr_wiring.html
Use the above site for several wiring schematics on dual voice coil speaker hookups. It will show how to wire for different impedance.
Also, I think the CVR 12's come in 2 ohm and 4 ohm impedance. See if you can check yours to determine which you have....
Jun 28, 2009 | Kicker CVR12 Car Subwoofer
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
Wiring
1st--on 1 sub put a wire connecting one red with white dot to the blk with white dot
2nd--do the same thing to the other sub !!do not wire a red/white to an all black
3rd--wire the full blk negetives to the amp, then same thing to the positive
Sep 21, 2008 | Kicker Car Audio & Video
Need to know how to wire 2 15 inch cvr to a zx1000.1 amp at 2 ohms
If they are 4 ohm single voice coil subs, just connect all the negatives together and then all the positives together. If they are DUAL vc's then need more info.
Aug 04, 2008 | Kicker Car Audio & Video
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
Kicker CVR12 Car Subwoofer Logo
740 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
