Question about Sony Handycam CCD-TRV128 Camcorder
Camcorder ejecting tape on its own
Hi, I am having trouble with my camcorder ejecting. Even if there is no tape in the camcorder, it will open on its own as if it is ejecting the tape. Can you help me with this please? I need to get some videos from my tapes to my computer, but I need to get this think working first. Thank you so much for your help. mctld
SOURCE: loading tapes
Hello, exact same problem here, closes fine when no tape inserted, but with a tape, the camera won't close, just keeps ejecting the tape.
Another problem that I encountered is that the camera will not take pictures anymore.
When I press the button, it beeps, but there appears a green dot on the screen,
My handbook tells me, when this dot appears on the screen, this means he camera will not take a picture, it however doesn't tell me how to solve the problem.
Anybody
Posted on Jan 05, 2008
welcomejee
  • 10594 Answers
SOURCE: Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Posted on Jun 07, 2008
SOURCE: sony hi 8 tape stuck
Take out the battery and put it back in. It should openthen.
Posted on Oct 16, 2008
quang123
  • 107 Answers
SOURCE: TAPE WILL NOT EJECT BLEEPING AND FLASHING C;32;11
You need your CAM into Sony or service center Sony to repair it the error code is indicated the LS chassis assembly faulty or loading motor faulty it require a lot of work mechanis and electronics it may not worth to repair it. It would cost between $150 to $250 in AUS
Cheers
Posted on Dec 04, 2008
SOURCE: I have a Sony DCR-TRV250 Digital Handycam
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Posted on Nov 17, 2009
Tape will not eject
Probably tape stuck, unless u know what u are doing take it to a repair shop. Fixing it takes a minute
Dec 31, 2013 | Panasonic Palmcorder PV-DV52 Mini DV...
Tape is stuck
First take out the battery. Then start unscrewing the outside panels to take it apart. Basically any screw you find, take off. The easiest way not to loose them is by sticking them into the side of a box. After you get the camera panels off, you should be able to carefully get inside and dislodge anything that may be in the way. Once you are able to dislodge the cord or whatever is causing this problem. Try inserting the battery and ejecting the tape. Let me know if you are having any trouble with this or have any other questions and I would be glad to help.
Good luck
May 20, 2008 | Sony Hi8 Hi-8 Tape
My Canon Elura 80, digital camcorder, has been acting up for the past year. First, it went through a period where it refused to eject the tape. In this, I mean I could open the side panel, but it would...
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 06, 2010 | Canon Elura 80 Mini DV Digital Camcorder
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
GL2 - Tape gets jammed everytime. Eject lights up immediately
This problem is usually related to the Dew Sensor, Unfortunately you can not by-pass the dew sensor. I paid a repair to fix, but he could not. Canon must repair the dew sensor.
I have same prob. I just capture directly to computer since my tape will not open. I would be interested in buying cameras like this, i can use them to still monitor images.
thebardeo@yahoo.com
Jul 06, 2009 | Canon GL2 Mini DV Digital Camcorder
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Tape will not eject servo reaches halfway but sticks XL1s
Try this...
Hit the eject button. As soon as it makes it half way, take the battery out.
Leave the white cover open, put the battery back in.
This should take the tape cartridge up all the way and eject the tape.
I had the same problem and it ejected the defective tape
Kawal
Jun 23, 2008 | Canon XL1S Mini DV Digital Camcorder
Tape eject door will open but tape will not eject
got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Apr 09, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
The tape ejects immediately after inserting tape
your m-chassis has a problem with it and when we get these we replace the chassis and adjust them you should send to canon for repair or a qualified tech. sorry
Dec 01, 2007 | Canon ES8200V Hi-8 Analog Camcorder
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Sony Handycam CCD-TRV128 Camcorder Logo
107 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
