Question about Sharp AL 1215 Black and White Copier
STAUS INDICATOR SHOWS "L-6" ON SHARP AL-1010
My Sharp Copier AL-1010 keeps displaying L6, does anyone knows what this means?????????
  • tommyg133 Jan 23, 2009
    TRIED WHAT WAS RECOMMENDED BUT DID NOT FIX THE PROBLEM!!! WHAT ELSE COULD I TRY????
    President:
  • Sharp Master
  • 990 Answers
Dear sir; The L-6 error code it means "laser drive, motor", It can be reset, the procedure as follow;
1, press "clear", "exposure mode", "clear", "exposure" those keys.then machine go dead.
2, enter 14, then press print.follow the direction willtake car the problem.
If you need more help just let me know I'm always around, or generously give me good rating. thank you,
HAVE A MERRY CHRISTMAS !!!
Posted on Dec 23, 2008
    Problem Solver:
  • 5 Answers
Hello Dear
L - 6 error has no solution, the only solution is to replace LASER Motor in Laser Unit.
Posted on May 14, 2009
We have a error code L 6 that keeps popping up. What is it?
L6 is usually a motor issue but need to know which L6--
Mar 20, 2014 | Sharp AL-1000 Copier
Red LED's on Sharp AL 1010 shaped like bowling pins
This is your out of toner indicator. I describe them as a stack of 6 dots. In any case you will need to buy a new toner cartridge or have your current cartridge refilled.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1010 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
LASER UNIT FOR SHARP AL-1010
GO ON LINE SHARP AL-1010 LASER COPIER SCHEMATICS.
OR THE LOCAL LIBRARY TO INDUSTRAIL COMMITION STANDARD COMMITION, THE BRANCH OF THE COVERMENT THAT REGULATES THAT PRODUCT SHOULD HAVE THE SCHEMATICS OF THE COPIER OF A DEALER OF THE EQUIPMENT SHOULD ALSO HAVE THEM ON MICROFISH, OR KNOW WHERE TO LOCATE SUCH THINGS, OLD TYPEWRITER REPAIR SHOPS MAY HAVE IDEAS WHERE TO LOCATE THAT DOCUMENTS AT
ROD
Feb 09, 2009 | Office Equipment & Supplies
NEED HELP WITH SHARP AL-1010
Hello sir; According our service manual 'L6" sub code 10 is laser drive, motor, problem, replace laser unit . the laser unit item# is DUNTK0013QSZZ, it located at left hand side of the toner cartridge inside the machine.
Jan 23, 2009 | Office Equipment & Supplies
Sharp -AL1644 flashing L6 error
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Feb 29, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL 1010
Hi, to reset drum light follow this sequence: press cancel, exposure, cancel, exposure. Display goes blank, enter 24, print, 07 print, cancel cancel. Cheers
Andy
Jan 25, 2008 | Sharp AL 1215 Black and White Copier
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
AL-1340 flashes L6
I think L6 means that it is not warming up you will either need a new fuser or control board to be honest I would say beyond economical repair.
thanks J
Nov 19, 2007 | Sharp AL-1340 Laser Printer
Sharp AL 1215 Black and White Copier Logo
309 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
