Question about Saws
Burgess BBK20 I can not keep a bandsawblade on my machine .It will run and track with a sanding belt but not with a b/saw blade
  • 3 more comments
  • John Walpole Dec 28, 2008
    I am using a new blade
    What do you mean by "crown the pullies"
  • John Walpole Jan 02, 2009
    Tracking is not a problem with the abrasive belt,but I cannot keep a blade on the machine long enough to check under power.I can however keep a blade on the saw by turning by hand in an anti clockwise direction,but by hand clockwise it comes off?
    John
  • John Walpole Jan 03, 2009
    I have taken thesaw guides off
  • Thomas F. Schneider May 11, 2010
    You are using a new blade? Have you tried to crown the pullies more?
    You are using new blades? Have you tried to crown the pulley wheels more?
    President:
  • 2,692 Answers
Instead of the face of the pullies being perfectly straight,a slight crown , meaning high in the center, will help the blade track to the center better. Most of the big band saws have crowned faces on the pully faces where the blade acually touches. The other option is to look for wear on the ajustment system or shaft(s) bearings.I am persuming no vibration while running.
Posted on Dec 29, 2008
  • Thomas F. Schneider Jan 02, 2009
    Have you checked the saw guides to make sure that they are in alignment with the blade are not pushing the blade off?
  • Thomas F. Schneider Jan 03, 2009
        Put the guides back on and by hand make sure that the back edge of the blade is just toughing the back guide support bearing enough to make the bearing rotate completely ,if it is a roller bearing.
        Lightly touch or a few thousands gap if it had a solid bearing. You can ajust the gap with a piece of paper if you have not  feeler gages.
Can the tracking on the sanding belt on the B&D belt sander 5.2A be adjusted?
yes ther should be a knob on the top front roller (top side) this should affect tracking , also make sure tension taker (lever for changing belt) Is fully off so that belt gets its full tension , if the belt doesnt get full tension it will walk side to side
Sep 22, 2014 | Tools & Hardware - Others
Burgess bbs20 band saw manual
I think your band saw is made and sold in England. Did you try posting on other forums. I suggest you visit this forum site . There are lots of members there who have the same bandsaw like yours. If you happen to be in US, I'd recommend you to check the blades of sawblade.com . Best blades I have are from them.
Nov 03, 2013 | Saws
Burgess bk3 bandsaw
the lining up of the blade on the top wheel and the lower one needs to be spot on the same. also don't be afraid to over tighten it a little more than it says. ie if you putting on a 1/4 " blade then tighten it as was an 1/2". hope this helps good luck.
Sep 05, 2013 | Saws
I need a toothed drive belt for Burgess BK 2 Also a thrust bearing for same.
I am quite certain that it would be hard to find parts of Burgess BK2 since the manufacturer discontinued the saw and not to mention, I think they're also busted. You try to check website that custom thrust bearings and drive belts.
Mar 21, 2013 | Saws
I have borrowed a ryobi industrial belt sander, I have put the sanding belt and repositioned the latch. When running the sanding belt keeps moving out.
There will be a tracking adjustment somewhere, usually a knob or wheel located at one end (axle) of the sander that allows you to adjust that... run the sander at low speed while you turn it until it tracks straight
Jun 10, 2011 | Tools & Hardware - Others
New blade will not stay on top belt
There should be adjustments for tracking the upper wheel. Turn the machine by hand until the tracking is perfect. Check the bearings in both wheels for looseness. Hope this helps!
Jan 21, 2010 | Saws
HOW DO YOU CHANGE THE BLADE AND TIGHTEN IT UP THE BAND BLADE CAME OFF & I DONT KNOW HOW TO GET IT BACK ON
Unplug it. Open the cover(s). Find the tensioning knob - this is usually right on top, and it is raises the top wheel (or ins some cases an idler wheel) - thereby tightening the blade. Lower the top wheel by turning the tensioning knob a few turn counter-clockwise. This will give you enough slack to re-install the blade. Wear leather gloves and reinstall the blade. Tighten the tensioning knob a bit. Turn the wheel by hand a little to see that the blade tracks OK. Tighten it a bit more. The correct amount of tension pretty much has to be determined by trial and error. If the blade comes off, or bends too much while you try to cut, or cuts poorly, then it's too loose. If you over-tighten it you can break the blade or prematurely wear out your machine. Close the cover and plug it back in. You can adjust the tension with the cover closed, and you can even tighten it while the saw is running. But I wouldn't loosen it while the saw is running.
Jan 20, 2010 | Ryobi 9 in. Benchtop Band Saw
I have a Craftsman 10 inch band saw. The blade keeps coming off. I can't find my manual. How do I adjust the alignment on it?
the blade tension shaft in the rear top of the saw should also have a tracking adjustment knob that tilts the top wheel. Open the top guard and spin the top wheel by hand and adjust the tracking knob until the blade atays on. Better unplug the saw until you get this done, then you can power the saw back up and fine tune the tracking while running until it is perfect. hope this helps you.
Oct 17, 2009 | Saws
How to adjust belt on skil belt sander
There should be a tracking adjustment knob on the side of the sander behind the front roller. Run the saw and adjust this knob to center the belt. You will probably have to do this every time you change belts. Hope this helps you...
Sep 11, 2009 | Sander Tools & Hardware - Others
My 16" Delta band saw blade is drifting how can I fix it?
The blade guides are not intended to prevent your blade from drifting they are there to ensure proper blade path while cutting forces are being applied. There is a tracking adjustment for the upper wheel. Unplug the saw. Start with light blade tension. Turn the upper wheel by hand while adjusting the tracking knob. When the tracking is close set proper blade tension and check tracking again. You can make fine adjustments to tracking with the machine running.
Jan 07, 2009 | Delta Saws
Saws Logo
192 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
