Question about Maytag Dryers
NO POWER HAVE POWER TO THE OUTLET BUT NO POWER TO THE UNIT.
  • 32 Answers
Replace hilimit thermostat, and check your venting it might be plugged and causing overheating
Posted on Dec 23, 2008
Tcl model 21k77
Try turnning your tv off, unplug unit from outlet, press and hold down the power button for 30 seconds, let go of power button, if plugged into surge protector try wall outlet, if plugged into wall outlet try a different outlet, power tv on using power button on tv. Did you have a storm in you're area?
Jul 24, 2013 | Televison & Video
AC unit won't turn on
did you verify that you have 110VAC between the neutral/ground terminal at the outlet? Most units require the ground/neutral leg for 110volt controls. Be sure that you hooked up a "hot to each leg and that you have 220/230/240 between the Hot legs and 110 between each hot and ground/neutral. hope this helps
Jul 20, 2009 | Heating & Cooling
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Not working will not power up
make sure outlet is working, use an extension cord or move tv to another plug if outlet does not have power, assuming you have power at the outlet, unplug tv and hold power button in for a minute, to completely discharge system, hopefully unit will power up after you plug in unit
Jul 09, 2012 | Samsung HC-R4755W 47" HDTV
Power pack light red
Hello, let's try a few things. First I would try to unplug the cables at all points. The wall, unit and power block in the middle. Reconnect and see if that helped.Be sure the unit is straight to the outlet and NOT to a surge protector or power supply or extension cord.
If not, I would try to plug the unit into another outlet somewhere. In a different room or something. Be sure the unit is straight to the outlet and NOT to a surge protector or power supply or extension cord. If that works, it's clearly the outlet in the original spot.
If none of these solutions help, if possible, see if you can borrow someone else's power supply and give it a try. If it works, then you know for sure that's all you need to replace. If it still doesn't work, you may have an internal power issue and will need a repair.
You can also find Microsoft's power supply trouble shooting guide here.
I hope this helps :D
Nov 24, 2011 | Microsoft Xbox 360 Console
Everstar mpm2-10cr-bb6 will not reset on power cord. light on reset doesn't light. seems like no power is getting to the unit.
Check the outlet that the unit is plugged into, to be sure that it is in fact, working. The circuit breaker in your home's circuit breaker panel for that outlet, may have tripped. Also, the outlet may have interior damage or a loose wire connection. If the unit seems not to be getting power, one of the above is the problem. Try plugging the unit into another outlet in a different room.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Danby DPAC8020 Air Conditioner
Plug the unit in, hit the power switch nothing not even the lights for the buttons.
Check the outlet that the unit is plugged into, to make sure that it has power. The circuit breaker for that outlet may have been tripped. Also make sure that the outlet is not damaged inside or there could be a loose wire connection or a frayed wire to the outlet.
Hope this helped you to start troubleshooting and solving the problem.
May 18, 2011 | Kenmore 54501 Dehumidifier
Remove the question mark
Reset the printer
  1. While the unit is on, remove the power cord from the rear of the unit AND the wall outlet.
  2. After one minute, reconnect the power cord to the wall outlet and the unit.
  3. If the unit does not turn on, press the On button.
Thanks
TechSaver.
Jan 20, 2010 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 2410 photosmart all-in-one
I have a questions for you, is the unit connected to a surge protector, or to a wall outlet.
If its connected to a wall outlet then the power supply will not be directly to the unit, as these units come with a built in surge protector in them.
You can try connecting the unit to a wall outlet, and if no go then try this step.
Disconnected the power cord from the unit as well as from the wall outlet.
Press and hold the ON button on the unit for 30 sec and then plug in the power cable to the wall outlet and then to the unit.
Remember to connect the cable to the wall outlet first and then connect it to the back of the unit.
This should probably fix the problem,
Please let me know if there is any other issues.
Nov 09, 2007 | HP PSC 1610 All-In-One InkJet Printer
Dryers Logo
32 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
