Question about Linksys Wireless-G WPC54G 802.11g/b
Linksy i can get a acess point but it says there is no internet found
  • gffd dfgdfg
    gffd dfgdfg Apr 12, 2007
    darth do i have to install the modem that connects to the acess point on the laptop.
    my laptop runs winxp home. it used to be a 98se
    and it is a compac armada
  • gffd dfgdfg
    45435
You have to run Win2K or better to get the card to work properly.
Posted on Apr 13, 2008
Um im new here but i am haveing the same problum as darth. the only diff is that i am running windows 98 se on a toshiba. the wireless card that i am useing is a linksys wpc54g. i have been messing with this thing for 2 weeks and i really need help
Posted on Dec 18, 2007
    Brigadier General:
  • 6,966 Answers
Hi, assuming you are running WinXP, you might want to try: 1) right click on your wireless networking icon and click repair; or 2) double click on the same icon; click on properties, scroll down to/click TCP/IP to highlight, click on properties - Tick Obtain an IP address automatically if your access point is also acting as DHCP server; or 3) get IP add + others from your Network Admin and entered numbers given; or 4) self-assign IP numbers that are pretty near your Access Point (AP) IP #s, maybe something like 192.168.1.3 where your AP is 192.168.1.1, subnet mask should be the same as your AP (normally 255.255.255.0 but may be different) and your default gateway normally would be the IP Add of your AP (192.168.1.1 or whatever the AP is using) DNS could be obtained from your ISP or tick obtain automatically. Caution here that the IP number you select should not be currently in use in your network. 5) Open IE, go to tools/internet option/connection, remove any dial-up if no longer needed and check never dial a connection (assuming you don’t use a modem and would connect normally via wireless. Go to/Click LAN settings, check auto detect settings, make sure Proxy server is uncheck. 6) Ping any website from your command prompt to see if you get a response If all else fail, pls post your AP hardware (brand/model), OS. It might also be a good idea to check if your AP is connected to an ISP with an active account and that your modem is working ok. Please let me know if this works out ok for you. Cheers.
Posted on Apr 11, 2007
  • Louie  Role
    Louie Role Apr 13, 2007
    Hi Darth, yes a modem has to be connected to the Access Point for you to be able to access the Internet. Without a modem, you can connect to the AP but you won't be able to access the Internet. Cheers
2 Suggested Answers
Philster
  • 113 Answers
SOURCE: connected to acess point but internet
The first thing you should try is connecting one machine via a cable to the router, to see if the connection is stable. This will prove the router is working, or not, as the case may be. Assuming the router still fails to function properly, you can then replace it.
However this assumes that the modem and internet connection are working properly. If either is causing the problems, then the router might be just fine.
But if the router does appear to work fine when wired in, then it at least proves everything outside the router is fine. And while it is possible, it is rather unlikely that just the wireless part of the router failed without killing the switch/router part.
So try this, and once we have the result, we can take the next step
Posted on Feb 01, 2008
How to fix internet sharing
Not sure if you try to set up a WIFI Access Point or are you trying to share internet access through a PC? I will try to answer anyway... You need to connect the RJ45 (that square-ish) to your wireless router on the WAN port.
Feb 13, 2013 | Computers & Internet
How to restrict adsl internet acess ?
please check the all pc mac address & this all mac adress u can do allow & deny in your adsl modem
Jul 05, 2010 | Computers & Internet
I want to hook up my dsi on my laptop but i dont kno how???????
you cant hook it up if your talking about playing the ds games in your computer use hypercam2 then type the game you want to play in google if your talking about the internet go to the game in the ds if your using the ds if your able to play wi-connection or if your using the dsi the go to the wrench in the left corner and click it the youl see a page scroll it to the right 2 times hit the bottom in the internet and click internet then put connection setting click in a bar that says none the click search for an acess point then it will search for one then click the acess point you want to use if it has a wep key then put admin do this only if your close enough to your computer
Feb 13, 2010 | Nintendo DSi Blue Console
Okay so im trying to use my dsi's internet and it says something (i forget what but thats not it)anyways i got to connection settings and put my password for the internet thing then i go to save and run...
if your using search for acess point it will find your own acess if you put manual setup it has 99% posibility that the error happens if it says no acces point in range move closer to your computer and it may work if it doesnt it means theres a problem with the telephone line so tell a fixer for the telephone line to help or tell your parents
Feb 04, 2010 | Nintendo DSi Black Console
Internet
This is very easy to fix. Go to the wii menu, and click "settings" or someting like that. Click on internet.
Then click none, wireless, and search for acess point. Click the thing with 3 bars or less. 3 is best, 1 is terrable. Then try to go on the internet.
Feb 02, 2010 | Nintendo Wii Console
Im on pre pay and when trying to access internet it shows- Packet data connection not available. What am I doing wrong???
check that you have got the settings to acess internet , contact the customer care they will send it for free or go to web application check the acess point is corrervt or not thats all
Oct 30, 2009 | Nokia N95 Cellular Phone
I dont know ho to connect for internet using nokia pc suit
Open PC SUITE > One Touch Acess> Configure>choose your type phone > tick on configuration the connection manually >It will show the information of GRPS such as: acess point name , Username and password you need fill it . But If u don't know what's the name of the acess point , username and password you need to contact your operator. After fill it finish Click on Connect and enjoy!
Mar 31, 2009 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Can't get internet on mi ipod touch!
To watch videos online from Youtube from you iPod Touch, you must be connected to an active internet connection via wi-fi.
To connect to a wi-fi access hotspot, Go to Settings>Wi-Fi. Now, look under Choose a Network':
-If there is a connection showing, then touch the network name to connect to it. After, retry Youtube and your problem should be solved.
-If there aren't any connections showing, then you do not have a acess point nearby.
-If you do not have a acess point nearby, you can always setup one at your very own home with a router.
Dec 29, 2008 | Apple iPod touch
Internet acess points
that means that it is not finding the wireless network signal. Are you within range of your access point?
Sep 09, 2007 | Sony PlayStation Portable (PSP) Console
Linksys Wireless-G WPC54G 802.11g/b Logo
216 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
