Question about HP Photosmart R817 Digital Camera
Camera self- diagnostic doesn't work
I get a blue screen that says
Camera self-diagnostic
Cameria R817
Firmware: 3.00.08
Serial # (it lists it)
Press RIGHT arrow to continue.
The problem is that when I press the right arrow, nothing happens. I tried resetting the camera with a paper clip as the HP site suggested. I have power. Any ideas?
  • CeciliaT Dec 28, 2008
    I have the exact same problem. When I press the right button, the yellow light by the menu button flashes a few times - almost like a confirmation, but nothing else happens. I LOVE this camera - I'm heart broken. I don't want a new one!
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Posted on Feb 22, 2009
I did almost the exact same thing as Tulip79, but... The camera I'm using didn't have a memory card in it to begin with. I was getting no response from any LED, finally took these steps.
  1. Turned the camera off.
  2. Took a memory card from a different camera, and placed it in the broken one.
  3. Turned the camera on, pressed right several times (The card LED flashed)
  4. Turned the camera off, and took the memory card out.
  5. Turned the camera back on, and pressed right... and... it worked! :D
Posted on Apr 12, 2009
My display screen doesn't work and the camera turns on but would not turn off
Hello. Do not know the model of your camera, but sounds like system internal error. Try to download the firmware for your model at kodak website listed under support. Be sure to get only the file for your model camera !!!!!
Best Regards, Russell
Dec 16, 2012 | Kodak Cameras
My Olympus FE 340 Camera firmware is crashed.Hardware is ok.Menu functions are OK.but when Im taking photo Screen is only dark black and shoting photos are same.I cant upgrade the firmware as My camera has...
I have a similar problem in the same camera: all hardware is ok but it doesn't focus. I've taked out the focus motor and it works, and all the pieces works too, they're not damaged, in fact wth the motor out I can focus manualy the picture. So I think it could be a firmware problem, but the OLYMPUS software doesn't leave me to write the same version of firmware, and there's no new versions, so is there any way to rewrite the same version of fw????? any service program?
Aug 26, 2011 | Olympus FE-340 Digital Camera
HP Digital Camera R717 Charging Flash Error
Try to run self-diagnostics test - press flash button while switching the camera on. One of them tests the flash functionality.
Nov 29, 2009 | HP Photosmart R717 Digital Camera
The camera turns on and takes pictures but the flash doesn't work. I saw the number 403 on the screen when I was trying to figure out the problem.
Try to run self-diagnostics tests - press flash button while switching on the camera. One of the tests verifies the flash functionality.
Oct 25, 2009 | HP Photosmart R707 Digital Camera
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Sep 09, 2009 | Office Equipment & Supplies
Images are green on camera and on screen session referenca # 922077
i think, .you should change the photo shooting mode.otherwise you reset your whole camera settings.if the problems will continue then you will change your lcd screen.
Jan 13, 2009 | HP Photosmart R817 Digital Camera
HP Photosmart R817
Something is wrong with the battery or the charging system. I just charged it over night and it works now. The battery still dosn't last very long .
Oct 07, 2008 | HP Photosmart R817 Digital Camera
HP Photosmart R817 5.1 Megapixel
Lens does not come ut when we turn camera on?
Jun 30, 2008 | HP Photosmart R817 Digital Camera
Screen not working
It could be that the connection to the screen has loosened up for some reason. If the warranty is void you can try to open it up (if you're up to it), taking the bottoms screws out, and then only the one's close to the screen side on the sides (hehe I hope you understand what I'm trying to tell you ;) )
The screen should be the first thing you see, if you loosen the 4 screws that hold that you can see the connection, just try to fasten it a little bit better, and then screw everything back to it's place.
Let me know if that didn't do the job :)
*I can not be held responisble if you decide to take something apart, It's your hands*
Feb 15, 2008 | HP Photosmart R817 Digital Camera
"Charging Flash"
i just posted the same problem a few minutes ago and now i have the solution!! got to this link http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=437509&lang=en
download the driver if needed (the firmware installation will tell you if you need it) and then download the firmware. immediately after i downloaded the firmware, the "charging flash" went away! hope it works for you too~
Aug 22, 2007 | HP Photosmart R817 Digital Camera
HP Photosmart R817 Digital Camera Logo
384 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
teddyboy
Are you a HP Camera Expert? Answer questions, earn points and help others
