posted by Rems on Apr 11, 2007
I have a problem which randomly appears. I have an ISDN terminal adapter connected to the serial port. This will work completly fine, then occasionally I get a timeout waiting for DCD, when I monitored the port with a "tap" on the times I get the timeout, it appears nothing comes out of the port. Has anyone else experienced the same or similar, and possible a fix.
many thanks rems
Solution #1
posted on Aug 01, 2007
This sounds like an IRQ inturrupt issue. Do you have other serial devices on this computer? If so, you might consider removing any other serial devices and see if the problem resolves itself. If it does, you will need to reconfigure one of the devices to another IRQ so that they don't interfere with each other.
Dan
Dan
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Magma PCI DMA Serial Adapter
Email this problem
Email this problem
Can you Help with these Serial Adapters problems?
Repair Service
Find Serial Adapter Repairman Near You:
