Question about OKI MicroLine 420 Matrix Printer
Oki Microline 420 print pauses
We are running this new printer on a MAC. The IP address is correct and the driver is installed. When we send a job it goes into the printer que but is automatically thrown into "pause" mode. Manually deactivating pause makes it attempt to print but reverts back to pause mode. We are frustrated. Any suggestions?
TAE U AMIN!!!!!!!!!!
Posted on Jan 08, 2008
  • 40 Answers
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Posted on Nov 29, 2008
  • 474 Answers
SOURCE: OKI B4600 Printer will not print = error - paused
Does it have a control panel or buttons on the printer itself?
If so, are any of them blinking or red?
Sometimes an error will cause a pause in the printer and you have to press one of the buttons to get it to start back up again.
This is the link to the manuf. website. I did a search on your model, theres a few so i guessed. but the manuals are available along with drivers.
I suggest you go and update them and go through the PDF and see if there is anything partaining to this issue.
I went through the PDF a bit and didnt see anything partaining to the PAUSE issue but try going through and see if anything is it.
On the printer icon on the bottom right of your task bar, right click on the printer icon and see if you can select CANCEL print job, then try unpausing it. Also, power off and then power back on and see if that clears it.
You may have to un-install the printer and re-install it and update the drivers to clear it.
Sometimes a Print job will get stuck in que when theres a jam or something and it wont continue till the issue is resolved, then you open and close the top cover and that resets it, it rechecks then continues.
Good luck.
Posted on Feb 04, 2009
  • 2692 Answers
SOURCE: I just want to know what the diffrent print
You can download the manual from your Okidata weblink below:
Posted on Mar 05, 2009
  • 8 Answers
yes the RS-232 Serial card is the same
Posted on May 08, 2009
I cannot connect to my 3Com OfficeConnect Wireless (3crwps10075-us) Print Server 3crwps10075
Check you firewalls. Sometimes you will have to allow certain mac addresses or certain ip addresses (may be less secure than the mac address), then change sharing level to full, before things begin to work.
Please post back and let me know if this helps!
Feb 21, 2012 | 3Com OfficeConnect Wireless...
Using Win7 - switches to NLQ mode every time regadless of driver used - Okidata Elite (Microline) 520, Okidata Elite (IBM) or Okidata 520. Tried changing drivers - none other available for Win7. With the...
This is a SNIP of a rather LONG FIX:
Found here:
"Just purchased this thing and am running it a machine to print checks with (Win95, p1-200, 48 Mb ram). The Oki dot matrix printers don't give you drivers, they tell you to use the drivers from Win95 disk. Sure... (just lazy if you ask me :-) OK using the Oki Microline 184 IBM Turbo driver the thing works fine, EXCEPT that it *always* prints in NLQ mode no matter what the settings in the control panel, it just switches to NLQ before each print job. So... we switch to a "generic text" driver and it works fine that way EXCEPT that it no longer recognises the custom paper length (8.5" wide X 7" long) Now here's the wierd part... IF I switch back to the win95 driver, re-accept the custom paper size, print a test page (in NLQ of course), switch back to the generic driver, re-accept the the custom paper size, switch the printer to normal (non NLQ), and print it works fine with the custom paper size and non-NLQ mode until the next time it needs to print. The printer remains ON 24/7, so its not reseting itself. It just seems that with the Win95 driver there is no way to set it to print in anything but NLQ AND the generic driver refuses to keep the custom paper sizes in memory. Anyone seen this before? Never came accross this myself. I may just end up sending this thing back and getting an Epson or someting else."
"This is like going back to the dark ages....most of those old impact printers had dip switches to set things like default print quality. Additionally, Oki's usually came in two 'flavors'--plain Oki and IBM Oki. It's important that you install the correct driver between the two options..."
Dec 25, 2017 | OKI MICROLINE 520 Matrix Printer
420 won't run on my mac 10.3 How do I fix that?
at the manufacterer website
contact mac - they rock - should help yah out - might be on the phone a while.
hope this helped da404
Mar 01, 2010 | OKI MicroLine 420 Matrix Printer
Oki Microline 420 Network Card
As the alarm is on and steady then you most probably knocked the change lever into a position where it detects no paper loaded. The easiest way to check is to load your paper and move the change lever until the error lamp goes out!
Sep 08, 2017 | OKI MicroLine 420 Matrix Printer
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
you are correct, you need a new print head OR adjust the head gap on the carriage
Sep 13, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MicroLine 420 Matrix Printer Logo
146 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
