Need to find the manual for a rth5100b thermostat
  • 700 Answers
Heres the link fo rthe manual that you requested sir, and by the way Merry Christmas and thank you for using FixYa
Posted on Dec 24, 2008
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual
www.manualslib.com > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ...
www.platt.com > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
This thermostat is mounted mid-wall on a brick wall and consistently reads 4 degrees warmer than 2 other thermometers in the room. Can the thermostat be recalibrated? How?
A manual for the thermostat is needed to recalibrating if doable, thermostat model number and brand needed to get the right manual.
A thermostat mount location should be planned. Any holes leading into the wall should be sealed, in other words, the thermostat needs to be insulated and isolated from fake temperature readings, no back drafts or not heat or cooling sources near by.
Jun 23, 2015 | Heating & Cooling
Need a manual for a yth9421c1010
Here is a link to the thermostat manual. For information on how to install a thermostat check out this link
Jan 25, 2012 | Honeywell Heat/Cool Thermostat
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
HONEYWELL RTH5100B , THE WIRES I HAVE ARE BLUE, GREEN , WHITE , YELLOW, BROWN, THE A/C WILL NOT COME ON SHOULD I USE THE BLUE WIRE AND IN WHAT ? RC, R, Y, W, G, THANKS
Hi , you need to make sure rc and r are jumpered together.
R=red
G=green
W=white
Y=yellow
Blue is probably the other side of the transformer (24v) and usually would go on "c" if the thermostat has that particular post. To know for sure where blue goes, trace back to the furnace. Blue will be attached to a marked terminal either on a transformer or a circuit board. Hope this helps you.
Jun 24, 2011 | Honeywell Programmable Thermostat Heater
Change thermostat
You have caught me without my old books, but I can tell you the orange wire is for the reversing valve on a heat pump. Almost all manufacturers, except for Lennox, are: R=Power (24volts), G=Indoor fan (Blower), Y=Cooling (A/C), and W=Heat. Some t'stat's are set up to use 2 separate transformers (24 volt), that is why you will see Rc, Rh. This is power for cooling and power for heating. If this is what you have, just take the Red wire and strip it back far enough to go under both screw terminals if the unit is a residential one. I've been doing commercial work for over 20 years and have never seen an "A" terminal, so I can't help you there. You may want to double check that. If I'm reading you correctly, I would put the orange wire on the "O" terminal. Don't understand why the "Y" terminal is not used. It turns on the compressor. The "O" goes to the reversing valve to "Tell" the outdoor unit that it is either in the cooling or heating mode.
Good Luck and let me know if I can help any further.
Feb 19, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
