What setting does the tv need to be in to find the digital channels tv or hdm1 or hdm2
SOURCE: Setup Wizard does not run AutoScan through to
get it to the local customer care
or there might be a problem with the signal reception
ask the service providers
SOURCE: My tv is not getting any digital channels.
have you tried switching the internal decoder on? If it has one thats is, check the tv's menu, or the manual that came with....
SOURCE: Emerson LD195EMX - just bought from Walmart,
Hey, most stations are not broadcasting analog anymore. That is why you are only getting 10 channels.
SOURCE: When I hit the autoscan it doesnt pick up
Pls be sure you have it set for "air" if using an antenna.....then do the scan........otherwise you may have a bad tuner
