Question about NCR 7875
Setting Scanner and scale back to default settings
I just came across four NCR7875 scanner\scale combos. I need to be able to set back to default settings. Any way to get this information without paying through the nose with NCR?? Programming manual would be nice.
  • 4 Answers
Print and scan the barcode below, this will set the NCR scanner/scales to defaults.
Posted on Dec 24, 2008
With our Scanner NCR7875 , we have problem with all EAN 13 digit barcode . its give starts with F and then barcode . like F123456789123. what to do ?
It seems like you have a suffix set on reading.
You should download settings manual, i'll guide you when you do that
Mar 11, 2014 | NCR 7875
How do I get the scanner to default to black & white and document feeder.
The scanner is a color scanner. If you're using the toolbox to scan, there is a setting for B/W. If you're using some other software there may be a default setting within the software to cahnge.
Nov 03, 2010 | Canon imageRUNNER 1023iF Black and White...
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
MS9535 BT Bluetooth Wireless Barcode Scanner Problem
Problem with Scanner settings .you have to load default setting to scanner from Configuration guide which comes with Scanner.
First Scan the Enter /Exit Configuration then select load defaults and at last scan Enter/Exit Configuartion.
Scanner will be o.k
Jul 07, 2009 | Metrologic Instruments MS9535 VoyagerBT...
CRE POS serial scanner doesn't scan
you can try to use a software package called Twedge...I've used it to solve issues just like you have above with a scanner scale and a Y cable...
May 29, 2009 | NCR 7875
HP G4010 scanner not scanning to scale. Where do I find the setting to make this the default?
my g4010 scanner is not scanning to scale despite using different configuration settings.
Mar 27, 2009 | HP Scanjet G4010 Flatbed Scanner
HP 3570 scanner not copying true colors.
Chuck the scanner (in my bin please) as the CMOS sensor is bad. Pick up a replacement at Goodwill for $10.00 and post for any help you need
Or sell it on Ebay for .99 + 20.00 postage.
Mar 27, 2009 | HP ScanJet 3570C Flatbed Scanner
Kyocera mita km3035
There are two ways to do this... from the panel or from the computer.
From the copiers panel
1) press the * button marked as System menu on the panel. Then you select "scanner default". you will be asked for a code. try 5000 if this does not work 6482 will. Now select "default settings"
The setting should be in here if memory serves me right. change it and at the top of the page be sure to touch on "Close" and not "back" touching "back" will result in that the setting will not be saved.
From your computer
1) get the scanner card's I.P. address. this is done by pressing the * button marked as System menu on the panel. Then you select "scanner default". you will be asked for a code. try 5000 if this does not work 6482 will. Now select "system basic setting" and write down the IP address shown on the display. Now Press the yellow reset button with the two white lines on the panel to exit. If you do not exit the menu using this button you will have to wait about 2 minutes for the scanner card to reboot.
2) from any computer connected to the network, open your web browsing utility (Internet Explorer if you're running Windows) and in the address bar where you would normally type the address of the website, type in the IP address that you wrote down in step1, and press enter.
3) In the left hand side of the screen, click on "Scanner default settings. the file format setting should be found in here. change it to PDF, scroll to the bottom of the page and click on "SUBMIT"
May 14, 2008 | Office Equipment & Supplies
No green ready light
There are two different type of port usually experience this particular problem.
1) If you use the scanner to com1 computer port
2) If you use the scanner to com1 cash register
The only way to settle the situation is to use the manual barcode scanner default settings.
1) Setting up default for com1 scanner
2) Setting up default for com1 cash register.
If you barcode still experience the problem you need to contact the manufacturer on that model or the reseller where you bought the said device.
Probably, the device being situated in critical effects that your scanner would not able to determine where it will send the data from your barcode scanner.
Please rate me solved if you like my suggestions.
Best regards,
Philip
Nov 13, 2007 | Opticon LGE1105RHHS-000 Handheld
Computers & Internet Logo
584 people viewed this question
Top NCR Computers & Internet Experts
Marvin
Marvin
gary433
 steve
steve
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
