Question about OKI MicroLine 420 Matrix Printer
Oki Microline 420 Network Card
We replaced our network card per instructions from Oki. The instructions indicate that the printer will reset. Flashing red light will then disappear. We have followed instructions and red light is steady. Printer que automatically places all jobs in "pause" mode. Manually deactivating pause mode will not work. Any thoughts or suggestions are welcomed.
Thank you.
  • OKI Master
  • 824 Answers
As the alarm is on and steady then you most probably knocked the change lever into a position where it detects no paper loaded. The easiest way to check is to load your paper and move the change lever until the error lamp goes out!
Posted on Sep 12, 2017
  • 32 Answers
SOURCE: microline 420
When the alarm light is blinking what other lights are on. This is the fatal error code with the printer.
Remove the ribbon. if still not moving smoothly unit needs service. 3 year warranty on this unit brand new.
If you cannot move the carriage back and fourth accross,
there is a seriuois issue. unit requires service.
Posted on Feb 12, 2008
  • 32 Answers
SOURCE: Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Posted on Feb 15, 2008
flopez
  • 161 Answers
SOURCE: oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Posted on Nov 07, 2008
  • 40 Answers
SOURCE: OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Posted on Nov 29, 2008
  • 2692 Answers
SOURCE: I just want to know what the diffrent print
You can download the manual from your Okidata weblink below:
http://my.okidata.com/PP-ML420.nsf?opendatabase
Posted on Mar 05, 2009
Where is the serial card located on the OKI Microline 320 Turbo 9 pin printer
if your looking at the printer as it sits on the desk it is located on the back left of the printer.
Aug 16, 2014 | OKI Office Equipment & Supplies
I have a OKI Microline 320 printer.
Your printer has a damaged mainboard. Very sorry, for yours is a very good unit. the replacement model is the Oki ML-420, which comes with a 3-year warranty.
Be blessed.
Oct 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 420
This would be the print head pins not moving forward or the ribbon bunched up at the top.
Sep 23, 2008 | OKI MicroLine 420 Matrix Printer
OKI MICROLINE 420
you are correct, you need a new print head OR adjust the head gap on the carriage
Sep 13, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MicroLine 420 Matrix Printer Logo
4,049 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
