Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
I have a fill fault problem with a DD603.
I have checked the water supply, the spray arm is rotating, could anyone tell me how to check the water block? any other tips?
Hi. You can check the water block by disconnecting it from the main tube and se if you can blow through the water block. Remember to turn the water off before you start :-) Yet I still have the same problem as described after checking that the water block was ok
Posted on Jan 25, 2009
What is a U1 code
U1 is a filling fault , so you will have to check the water supply into the dish draw is turned fully open and the hose is not damaged or kinked . Ensure the spray arm inside the draw is free to rotate and clean out the strainers inside as well .It would also pay to check the levels on the machine .If you run the dishwasher whilst using water else where the water pressure may also be dropping to much or even changes in temperature may effect it .
Good luck
Aug 29, 2014 | Fisher and Paykel Dishwashers
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
IT STARTS TO FILL BUT THEN STOPS, DOES NOT DO WASH CYCLE dwd4310w dishwasher
You have to check the water flow from the pum end. the spray arm rotates under water pressure only. Try cleaning the hose if possible from front. Clean the rotating arm also. jet holes
Apr 11, 2010 | Dishwashers
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Water not spraying hard enough
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Sep 30, 2007 | Whirlpool GU1200XTLS Stainless Steel...
Very poor cleaning all of a sudden
suspect blockage in the actual spray arms - take them out and clean under the tap. a check is to open the door when in operation and see if the spray arms are rotating. they are made to rotate only by the force of water thro angled jets at the end of the arms
Mar 26, 2007 | Kenmore 24 in. 16263 Dishwasher
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
319 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
