Question about Samsung T260 Monitor
No display on Monitor
I just purchased a Samsung T260 Monitor. The first thing I did was to plug the new monitor into my PC to make sure my old monitor was indeed dead. At this point I had not changed the graphics card or installed new drivers. The monitor seemed to work properly though the picture was poor. I assumed this was because I was still using the old monitor graphics card and drivers. I then installed the new graphics card and drivers. I turned on the computer and found that the new monitor would only display a small message box (forgot what it said) and nothing else. I then plugged in the old monitor graphics card again but this time the monitor would only display the message box and nothing else. What have I done and how do I fix it? By plugging in the monitor with the old graphics card and drivers have I somehow compromised the new monitor in some way? If I hook up the new monitor to an older computer that I have, the monitor works with very poor quality. Any help you can give is greatly appreciated!
SOURCE: LCD problems... Can you help me?
i already made an investgation about it, seem s that the main board of the lcd "pass away", so it only works few minutes before shut down the screen and show us the famous warning.
The only solution is to change the circuit board, not the power board for the lcd. definetly is NOT a PC failure
Posted on Jan 25, 2008
SOURCE: Resolution Issue "Not Optimum"
Hi Guys.
I have had this problem and after a bit of searching found that it is a known problem.
Give Samsung a ring and if it's in warranty they will replace it
Posted on Mar 13, 2008
yooperbud
  • 8637 Answers
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Posted on Jan 09, 2009
benwabnick
  • 2404 Answers
SOURCE: Samsung 932B Plus monitor does not turn on. Blinking LED
If you can open up the monitor from the back and get the cover off. Look on the power board and see if there are any puffy capacitors, most of the caps will have a silver flat top but if there are any bad ones, they will have a puffy top that stick up.
If you see any then make sure you replace them with capacitors of the same Uf rating and at least the same volts or more.
If you don't see any puffy caps then that means the screen is bad and the whole monitor would need to be replaced.
Posted on Nov 30, 2009
Testimonial: "Opened the LCD monitor up, and it was as he said. A bad capacitor. Thanks!! Replied within minutes."
  • 1684 Answers
SOURCE: I have a Samsung Syncmaster 2493HM monitor. The
Your power supply is going out. LCD monitors have a common issue. The heat buildup in the in the cases cause parts called capacitors to overheat and bulge. When they bulge out the don't operate properly and cause the power supply to not start up correctly or not at all. First thing check the warranty, Most Samsung units have a 3year parts and labor warranty. If it is out of warranty then repair it yourself. If you can solder then you should be able to do the repair yourself. Check out our web site at:
www.ccl-la.com We don't have your exact monitor but you should be able to look at other Samsung guide we have posted and see the parts that need to be replaced. Open your case and replace any capacitors that are bulging and you should be back going again. If you don't want to do the repair yourself we do offer a repair service for you unit, check our site for details.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
Screen stops working after 1 second of working
if no any power indicator at the front panel, you must need to check the power supply board. look for a burnt parts or blown fuse just replaced with new parts.
Dec 28, 2012 | Samsung SyncMaster T260 - flat panel...
Panel lcd broken samsung ls 26tddsuv/en
I recommend you buy a new monitor, since just fixing the panel would be more costly then buying a brand new monitor. Check out www.newegg.com or www.tigerdirect.com for some good deals on new monitors.
Jan 15, 2012 | Samsung Computers & Internet
It would randomly just go blank then cycle through all the inputs (hdmi,analog,digital) as if it just all of a sudden it had no digital signal ( im using the dvi connection) . I know it is the monitor...
Sounds like you need a new monitor! If you "witched" the towers and the problem persisted wouldn't it be logical to suspect a bad monitor? I know when I witch my monitors the act up!
Jul 09, 2017 | Samsung SyncMaster T260 - flat panel...
I am having problem with a Samsung 712n monitor that remains black when the PC is booted up. The PC drives other monitors all right, so the trouble is not the PC. The buttons on the front of the monitor...
The monitor should be replaced, by your description there is more than one issue, it has a screen display problem and several buttons are not responding to any commands, and the monitor is six years old. The cost to repair would not be justified, and a new replacement would be cheaper.
Jan 10, 2011 | Samsung SyncMaster 712N 17" Flat Panel LCD...
My monitor stopt working a few days ago. The problem is that when i put my monitor on it sees windows on digital and after 1 sec it shoots away and goes to analog then hdmi and stops. It just dont want to...
You need to check display resolution settings.
Also make sure graphic driver installed and working fine.
For that when you power up the computer press F8 key 5 to 6 times then you can see safe mode and other menu.
Enter in Enable vga mode and go to control panel->display property->settings change screen resolution to 1024*768 then apply and check.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 16, 2010 | Samsung T260 26 inch Monitor
I just purchased two 40in lcd samsung monitors and connected them via vga to a digital player. One monitor works fine and displays the picture correctly. The other monitor is only displaying the top left...
If the two monitors are identical adn the player works on one then it should work on the other.
Try plugging the monitor that appears "broken" into another device (such as a PC) and see if it works or not.
Dec 09, 2009 | Samsung Computers & Internet
My pc monitor is going faded , it clear after 20-30 minute, , when i start it it become faded . nothing is seen on screen . screen is going so bright and text is not understandable , and after 20-30 minute...
I'm affraid that this is not a software issue but a hardware one.
If you're not a tech expert all you can do is check the plugs and cables for damage but I seriously doubt that it would help.
The best thing you can do is either go to a service center (and pay for repairs) or buy a new monitor (and pay for a new monitor)
Sorry and best of luck
Nov 10, 2009 | Samsung SyncMaster 750 (Ivory) 17" CRT...
Screen tearing
You have a high quality monitor with a 5ms response time, so it is not the fault of the monitor which leaves two things.
1) Cable If you are using a VGA (blue) connector I would reccomend upgrading to a DVI or HDMI cable. Digital cables like HDMI and DVI not only look way better than VGA (analog cables) but they deliver quicker response times, and reduce graphical errors. You Should always run a digital output if possible.
2) Software In games in the graphics settings, you might want to enable "verticle sync" this will limit the refreshrate of the game to usually 60 fps, which will reduce and possibly eliminate tearing.
May 24, 2009 | Samsung SyncMaster T260 - flat panel...
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Samsung T260  Monitor Logo
69 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
