Question about Hon Company HONMST60 Tripod Screen, 60"x60", Matte White Screen/Black Trim Projector Screen
The screen won't stay up.
The red button that you push has a tab that locks in the holes on the square shaft that extends to hold up the screen.
On the unit I have, the tab is broken off (probably during shipping) and the screen won't stay up.
How can I get a replacement part to put this unit back into service?
Dc17 won't turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor.
Nov 18, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to remove sliding door inside panel of Mazda MPV
1. Work with slider in open position. It helps if you are on a slight incline so that door stays in fully-open position and won't slam shut on your fingers.
2. Remove inner handles and door panel:
a) Inner handle. Remove the inner handle first. You can't see it too easily but a wire clip about the same thickness as a large paper clip holds the handle to its shaft. It's shaped like an upside down "U" so it needs to be pushed straight up. Press the panel outward around the handle and you can just see the clip. Use a small thin screwdriver to locate the bottom tips of the clip and push it up. You may have to alternate from side to side but it will pop off. Grab it with a pair of needlenose pliers if you have to. The door handle willl now slide off - just pull it towards you.
b) Power window switch. Remove power window button by squeezing hidden tabs along the sides of the button. Again, you may have to push the panel outward a little and pry the switch to see the tabs. Wiggle it a little and the button will release. Pull it out and unplug the wiring harness.
c) Door panel. There are several plastic buttons which hold the panel on at the bottom and up the sides. Use a plastic putty knife to get behind panel and pop it out of the holes.
3. Once all trim fasteners are released, grab the door panel at the bottom and pull straight up to release it at the top. You may have to give it a quick upward tug to get it to release. Push the power window button wires through the mounting hole. Look at the panel buttons to make sure that all of them came off with the panel. If not, remove the remaining ones from the door and put them in their respective slots on the door panel. (Trying to re-attach the panel without the buttons installed on the panel will be frustrating.)
4. Outer handle removal.
a) Unclip the handle lock button / bar by turning the small tab and pulling the bar out of its slot. Hard to describe here but you'll figure it out once you see it.
b) Remove three bolts which hold the handle on the door. Note that one bolt is accessible from the outside of the door along the front jamb.
Replace handle and reverse the steps above.
Notes: Check the locking mechanism and make sure the door opens and closes before you reassemble the panel. Remember to orient the inner handle the right way before you re-attach its spring clip. (I've attached it upside down and it won't work!!!) . Also, be sure to feed the power window wiring harness back through the mounting hole before putting the panel back on.
Nov 06, 2012 | 2000 Mazda MPV
1995 toyota avalon will not shift from park. won't start. what can I do? Want to try to push it out of blocked parking spot to try and jumpstart.
THE SHIFTER GAS A HARD PLASTIC BOOT EITHER ON THE TOP RIGHT OR LEFT OF THE BOOT OR PLASTIC SQUARE THERE SHOULD BE A SMALL PLASTIC PIECE USE FLAT HEAD SCREWDRIVER PRY UP THE LITTLE SQUARE THEN STICK SCREWDRIVER IN HOLE WHILE HOLDING FOOT ON BRAKE WHILE DOING BOTH OF THOSE THINGS SHIFT VEHICLE THIS LITTLE SQUARE IS CALLED THE SHIFT LOCK OVERRIDE
Oct 30, 2011 | 1995 Toyota Avalon
How do I remove and/or insert wires into Leviton Decora switch interruptor model 5601. Back of switch says "push to release" with arrow pointing to small square hole. What do I push to release...
Hi Ray,
Take a small screwdriver and push into the hole just far enough to release the wires. Your pushing down an inclined pinch tab that is copper and locks the wire to the side of the switch housing along with making the electrical connection. So push in gently with small screwdriver or push another solid piece of wire into the release hole to unlock the wires. It isn't that hard to do. Sometimes you may actually have to slightly push in the old wire to unlatch the locking pinch tab while also pushing in the release tab. .
Thanks for choosing FixYa,
Kelly
Jan 17, 2011 | Leviton 107-5601-2WS Single-pole Switch
I took my Hitachi NR83A apart to remove a jambed nail, and can not figure out how it goes back togeather. Where does the tension apparatice go inrelation to the shaft and slide handle? Thanks Vince
You do not need any special tools to assemble the pusher into the rails, however there is a trick to getting the spring in the proper position. I use a small pair of vice grips and a paper clip to hold the spring in position. The pusher slides into the rails easily. The back part of the pusher slides into the rails first. On the back part of the pusher there is a groove that accepts the spring, spring spool and pin. The pin will be in a vertical position and the spring will have the end tab with hole towards you. As you push this assembly into the rails you will loose sight of the spring end tab. You must hold the spring end tab at the bolt hole while you push in the assembly. This is done by bending the paperclip straight with very small hook on one end. Hook paperclip on spring tab hole and hold paperclip with vicegrip to position spring tab hole at bolt hole and push assembly all the way into rails untill it locks at rear or rails. This procedure can be varried with goal of holding spring tab at bolt hole. While holding tab in position insert rails into nose of gun and bolt rails. Just leave paper clip hook end there or pull out it does not matter. You are done. Good luck
Aug 05, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
My Dyson will not lock into the stand position
- Stand behind the vacuum cleaner
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- WHilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square holse basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Jul 16, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson dc07 will not lock into upright position
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square hole basically)
Jul 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson upright suddenly won't stay in the upright position. It appears that a little rubber piece has fallen out of position.
hole basically)
Apr 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I am trying to clean the inside of my microwave, ut I don't know how to remove to disc on the top, which is full of grease,how do I do it!!
Hi, If you look at the plate on the top it has what looks like a little button and printing that says "open" with an arrow pointing to the left and one pointing to the right that says "close".
The little button is actually a tab that you can carefully remove by using a butter knife and sticking it in above the tab where the plate meets the top. The tab is about 1/4 inch long. After you remove the tab carefully turn the plate to the left and slowly drop it down. There is a slotted disk on a square shaft above the plate that may (probably) drop down with the plate. The plate holds the disk in place and is actually the bearing for that disk so be sure to slide it back on the shaft as you put the plate back. turn the plate to the right and then push the tab back into the hole. Good Luck!
Jan 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
Nov 13, 2008 | Dremel 300-N/55 300 Series Tool Kit
Hon Company HONMST60 Tripod Screen, 60"x60", Matte White Screen/Black Trim Projector Screen Logo
57 people viewed this question
Top Hon Company Televison & Video Experts
Marvin
Marvin
Are you a Hon Company Televison and Video Expert? Answer questions, earn points and help others
