Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Turn camera on and it beeps twice then shuts off after 5 seconds
Everytime I turn my camera on in the picture capture setting it beeps three times and then shuts off. The lens wont recede back in though so it is constantly pulled out. Also, if I turn camera on in the view picture format it works fine....any ideas??
  • 1 more comment
  • Matt Frey Jun 05, 2007
    I did the slightly turning first the big ring until the click, then turned it on and softly turned outer ring...fixed...thanks so much!!!
  • ELMOSYSWORLD Jan 06, 2008
    MY CAMERA'S SILVER LENS THINGY IS STUCK ON THE OUTER SIDE AND IT WONT GO BACK IN =[ SOMEONE HELP ME FIGURE OUT HOW TO MAKE MY LENS GO BACK IN!!
  • Herbert Maker Jan 31, 2008
    same troubles any new help, I tried the other ways of bring the lens in.
I Totally fixed my CAMERA!
If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me.
You need to unscrew the outer casing and take off the metal shell.
Hold the camera in one hand, palming it, looking at the LCD (ie the lens is pointing into your palm). This is to orient you.
If you look at the left SIDE of the camera, near the upper left corner of the LCD, you can peek through some of the windows of the black casing and see 2 PLASTIC GEARS. One is white, the other is black. These are the gears that actually move the lens in and out. All I did was give the white gear a good jiggle with the tip of a pen and evidently it made the teeth of the gears mesh together like its supposed to and .... VOILA .... the lens came out when I powered it on and all is well! I know this is gonna help someone!
Posted on May 24, 2008
I had this exact problem... found this solution posted under a similar problem, and it worked. See below. posted by Richardrich on May 08, 2006Report abuse no display on screen just beeps twice.zoom is stuck open.It's fully charged Best Solutionposted on May 09, 2006 By carlos-aec Rank: Master Rating: 76.36%, 55 votes Before you try any of the suggestions below, make sure the camera has fresh batteries and that it is in picture taking mode. First, try hooking your camera up to the TV with the included A/V cable. Second, try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all sand and dust. Turn the camera on and it should function fine. (Thanks Sprocket) Third, try the tap method. Tap the padded usb cover part on a hard surface (e.g. a desk). (Thanks Tania, et al) Fourth, try forcing the lens. Version #1: This error occurs when the lens is "stuck" or not extending "straight". The error can happen in 3 ways: either when the lens wont "come out", or "comes out" and then retracts, or does not retract at all. 1) If the lens doesn't extend at all or it extends, but then retracts again, do as follow: Turn the camera off. Place the camera on it's back with the lens facing up and have a look at the "spacing" between the lens and the lens housing. You'll probably notice that the gap is NOT EVEN all the way around. To fix this, simply -VERY GENTLY- press down on the side where the gap is the biggest. You will hear a "click" as it pops back in place. Try powering it back on. 2) If the lens is extended all the time and won't retarct at all, do as follow: Turn the camera off. Take the camera in one hand and with the other gently, in turn, take the two part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on. (Thanks Mike Scher) Version #2: Pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. You may find that the focus seems to improve. (Thanks Jeff Kishiyama) If that doesn't work, there are a few online guides for repairing it yourself. (NOTE: This route is only worth trying if your camera is no longer under warranty!): Was this solution helpful? Show your Appreciation by rating it: = Irrelevant = Poor = Average = Good = Excellent Solution #2posted on May 09, 2006 By bmwrider Rank: Master Rating: 78.58%, 691 votes I wish this guy with the twist it blow it and bash it would take his advice eleswhere. He reckons it's the cure all for every digital camera with an extending lens. I've had a couple of the RR10s exhibit no life except a few flashes of an LED. The simple fix was to firmly squeeze the lower half of the camera's front and rear together. What happens is that either over time or if subjected to a slight shock the two main circuit boards part company at a rather large multipin plug and socket. Squeezing the front and rear (just above the hump at the bottom front of the camera)makes this plug and socket return to where they should be. The first one took me about 2 hours trying to figure out but the second took me about 4 seconds to get working again. WARNING don't overdo the squeeze be firm but not aggressive. I use both thumbs on the front and fingers on the back but stay clear of the LCD.
Posted on May 05, 2007
My son tried to connect his ps3 to the tv via the hdmi lead the sound comes on but no picture can you help please
okay you have to reset your ps3 tell your son to turn ps3 off then hit power button hold your finger on it till it shuts off then hit it again till it beeps twice make sure your tv is on and you HDMI is hooked uo properly it usually beeps twice about 5 to ten s4econds after you hold it a second time for the 2 beeps you have to be quick at this
Mar 20, 2013 | Video Game Consoles & Games
Beeps three times and shuts off
The lens is jammed. It requires manually resetting. If you in the U.K I can help you out. email me at kiddo242@hotmail.com
Aug 09, 2009 | Polaroid i631 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
S630 camera not working !!!!!!!
If the camera was dropped, then it's really causing those kinds of issues.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved - Turn off camera for a few seconds so that settings will be refreshed
Third, you could try cleaning the lens with a soft clean cloth.
Make sure you are wiping gently.
Fourth, try to take a picture using this way:
- Press and hold the shutter button halfway first for 3-5 seconds,
and then press it all the way down
Fifth, if it still does the same thing, then your camera needs to be repaired by a technician.
If you want to know where you could send it, just call the hotline of the manufacturer of your product so you could get assistance
about this matter.
Jan 10, 2008 | Samsung Digimax S630 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Camera beeps twice and then shuts off. Does let me look at pictures.
You have a "lens error". That is something that can only be fixed by sending it into Casio. I would call them first and they will tell you everything that you would need to send in. Their number is 800-706-2534 and then keep choosing option 1.
Jul 07, 2007 | Casio Exilim EX-Z57 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
315 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
