Question about ICOM Informatique Audio Players & Recorders
Lost TX ability with Icom Commandmic II
I have an Icom CommandmicII used in conjunction with an Icom 402 VHF which will no longer transmit. I have been told by receiving stations that my signal was weak when using the CommandmicII, but OK when using the Icom402. I have flushed the mic to remove any salt build up, to no avail and have eliminated the possibility that the cable between the remote mic and the 402 is the problem, by trying to transmit with the remote plugged into the back of the 402. All other fetures on the remote mic work fine.
Can you suggest anything else I can try before I purchase a replacementreplacement?
Thanks.... Mike
SOURCE: "weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
SOURCE: No sound from receiver TX-SR604
Make sure that the zone 2 audio source is not digital
Posted on Dec 22, 2007
  • 4234 Answers
SOURCE: Onkyo TX-DS838 Issues
The problem here is that the output amplifier section has a problem. This is detected internally and the system shuts down in a "protect" mode. The output section really only kicks in when you attempt to bring up the volume. Another possibility is a problem in the "front end" where DC current is being passed to the amp section. Without takeing measurements, it is difficult to determine the exact cause. This should be a relatively stright-forward repair for a service shop and should cost about $20-$40 in parts plus the local labor charge.
Dan
Posted on Mar 17, 2008
biigg53566
  • 99 Answers
SOURCE: No Signal on Lubbock, TX channel 11.1 but receive all others
When the Government decided to make all stations go digital, most places we're telling about the change over. But what they forgot to mention to the ones like you that you may have to change your outside antenna. They make antenna just for picking up digital signal. So you may have to change that also. be Sure and check the cable going from the ant. to back of the converter box is in good condition or may have a break somewhere that could cause more trouble. If you see any bad places on the cable you may want to replace it now when you do the antenna.
biigg53566
Posted on Feb 19, 2009
  • 121 Answers
SOURCE: lost my set up mic
Page 67 of your manual will give instruction on the manual setup of your system. If you do not have your manula please look here:
http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
Posted on Mar 24, 2009
I can transmit from my ic-v80 to motorolla a8 but they can not transmit on me
check RX/TX frequency must be same, also check QT/DQT, this option at both radio must be same or disable.
Apr 12, 2014 | Icom IC-V80 Sport VHF Handheld Two Way...
Icom ic-m35, no transmitting
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
Aug 17, 2013 | Icom IC-M36 VHF Marine Radio
Not transmitting
Contact ICOM service at www.icom.com, or take it to a marine radio service center.
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
Icom IC-M34 transmit correct but do not receive if sql is above 0
Sound like a speaker problem, dosconnect the speaker and check it with a meter, it should read 8 ohm. Good luck.
Mar 13, 2011 | ICOM Informatique Floating Hand Held Vhf...
Hello, Can you tell me what make of GPS will work with the Icom m-504. I tried using the Garmin 76csx with the NEMA in/Nema out function set, but it will not communicate to the Icom. I would appreciate...
Hi!
We had the same problem with our Uniden Oceanus failing to communicate with our GPS. What the problem was, was that our VHF didn't recognize the NMEA sentences transmitted from our "ancient" GPS. We ended up buying a Standard Horizon cp180 chartplotter. PRESTO! Our DSC capability materialized.
Your 76CSx is newer than our Magellan was, so before you take on the task of a $400 chartplotter purchase, just make sure your BAUD rate is set to 4800. This adjustment alone could make your GPS work with your ICOM.
Hope this is helpful.
Jan 23, 2011 | Icom IC M504 Black Submersible PLUS Marine...
How do I reset the F221 to factory settings. I cloned the unit with V1.6 of the programming software with updates that included turning on the user start password and now the box will not communicate with...
F121 VHF, F221 UHF they both use the latest Version 1.7.
For F121 Factory default as follows:Open your CS-F100 software, enter RX TX frequency below, and write to the radio.Ch1: 136.100 MHzCh2: 155.100 MHzCh3: 173.900 MHz
For F221 Enter RX TX frequency belowCh1: 440.000MHzCh2: 460.000MHzCh3: 489.000MHz, then write to your radio
Or you check from this site:http://www.two-way-radio-tools.com/icom.html
HP
Feb 04, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
83 people viewed this question
Top ICOM Informatique Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an ICOM Informatique Audio Player and Recorder Expert? Answer questions, earn points and help others
