Question about Canon imageRUNNER C3220 Color Copier
How do I change the roller in the fuser?
I have a Canon C3220 and 1 of the rollers is bad. How do I get the old one out, to put the new one in?
  • printing_etc Dec 26, 2008
    I thought I was doing something wrong? Turns out, those rollers are almost impossible to replace.
  • 168 Answers
Im assuming your talking about the upper roller in the fuser? if so you need to take the unit out 2 silver screws on top looking back at you. and replace the unit try ebay. those rollers are very difficult to do
Posted on Dec 23, 2008
  • andzulisv Dec 26, 2008
    yes thats right thats why i said order a unit
Hello every one, i have iR Canon 2420 copier, first time i have a problem on the fuser and i changed it with the new one. After that the machine copy correctly but the text copied will be erased easil
Dear
The fuser unit consiting of two pars
1-fixing film assy. (Heter unit)
2-fixing unit-(Complete set.)
if you have replaced new fixing film assy. in old fixing unit-this may be the result due to the pressure roller and it allied parts.
if you have replaced complete unit then check you toner and paper properties.
Thanks.
Dec 02, 2014 | Canon Office Equipment & Supplies
Fuser upper roller problem
Apparently you just need the pressure roller, if noisy, you can change the bearing.
Good luck ...
Apr 24, 2012 | Canon imageRUNNER 8500 Copier
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
Copies and faxes double images how to solve
put an old or new toner cartridge in it to see if the double imaging goes away. If it is still there its the fuser. I can help you with that if you need supplies for the fuser. Steven 818-888-0006
Mar 05, 2010 | Canon imageCLASS D880 All-In-One Laser...
My old Canon NP1215 Copier: -First copy is
most probably a change of the drum and cleaning blade is needed ,check also the fixing/fuser roller
Jul 11, 2009 | Canon Office Equipment & Supplies
Paper will not go through output rollers - jams at crumples
ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
May 15, 2009 | HP LaserJet 1300 Printer
Upper (gray) fuser roller needs replacing, (tear on 1 side).
If you are handy it is not hard to replace the upper fuser roller you will need a small phillips screwdriver and pliars
the fuser lamp goes through the fuser roler so youmust disconnect the power leads to the lamp and remove the lamp
You do have to release the back side of the drive
gear on the fuser roller
when you install the new roller be sure to put some silicone fuser oil on the cleaning pad
take your time good luck
Jan 04, 2009 | Office Equipment & Supplies
Canon IR3170CI got a error E0014-002
k these are notorius for having bad upper rollers if they sit for a long time if you turn the green knob on the fuser and feel hesitation or its hard to move then easy.. or if it sounds like a washing machine at warm up you need a new fuser even if youswapped it the one you put in if not new may be bad
Dec 10, 2008 | Canon imageRUNNER 400S Copier
Paper Jams
How many copies has the copier done ?
When was the last fuser fitted ?(heated rollers)
the fuser rollers have a life of about 100,000 copies
and you change the whole unit at 200,000 copies
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3220 Color Copier Logo
198 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
