Question about HP PSC 2410 All-In-One InkJet Printer
Won't pick up paper and won't print
The machine will fax, but won't do anything else.. It sounds like it is locked up. It will not pick up the paper or print. It makes a clicking noise when you try to print something or copy something.
    Problem Solver:
  • 14 Answers
Did you have any recent jams that may have left a bit of paper in the printer?
Posted on Apr 24, 2007
Won't recognize paper size hp document
HP's are notorious for not recognising paper sizes. Especially if you are out of the USA. HP printers are default set for USA paper. I have to set mine every now and again to the UK paper size system before it will print within the borders.
Go to paper selection etc and set the paper sizes before you print. Eventually, they do memorise the settings, as odd as that sounds.
Nov 22, 2013 | HP Officejet 4500 All-in-One -...
Paper won't feed through to print my faxes.The mechanism sounds like it is turning to pick the paper, but it isn't feeding through. As an alternative, can I use the USB port to copy the faxes onto a USB...
That model quite often breaks plastic parts that hold the gears together in the sheet feeder, a new sheet feeder will run around $49.00, there's no way to transfer faxes out of the machine without printing.
Nov 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Our HP laserjet M2727nf does not feed the paper to print anything
just clean paper pick up roller whit wet cloth or alcohol...you can do this for ADF pick up rollers too if someday have the same problem whit ADF. Good Luck!
Oct 05, 2009 | HP Laserjet M2727nf Multifunction Printer
THE FAX MACHINE CAN RECEIVE THE FAX IN THE MEMORY BUT FAIL TO PICK UP
My office fax machine can receive the fax in the memory, but it does not print it.
May 19, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Borhter 2820 doent print
Typically when a machine asks you to use the bypass tray it does not like the size of the paper you have in the machine.
sounds like a paper size problem, check the paper guides in the machine, make sure they are up against the paper. Make sure the paper size in your printer driver is the same as the paper in the machine.
Failing that, power off the machine, unplug it, let it sit for a couple of minutes, power it back up, this cleares anything in the volitile memory.
Hope this is of some help.
Ed
Apr 26, 2009 | Brother IntelliFax-2820 Laser Fax
Paper is not "picked up" to print.
TRY CLEANING THE PAPER ROLLER WITH DENATUYRED ALCAHOL OR MAY BE THERE IS SOME THING STUCK IN THE MACHINE GO AHEAD AND LOOK GOOD LUCK BROTHER TECH
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Machine ran out of paper during fax trans., how to prnt memory?
Most of the time putting paper in the machine will allow it to continue printing anything that is in the memory. Other functions such as recall etc etc are not available on these low end models. For example this model does not have a harddrive. Usually a bad fax situation like this will lock the machine up. This forces a clearing out of the memory to bring the machine back to life.
Sorry, but this is by design.
Dec 31, 2008 | Canon FAXPHONE L80 Laser
My Laser Panasonic Fax won't pick up papers when sending faxes
There is a sensor in paper tray .u will see just its lever at the other end of lever there is a sensor .i think it is dirty .just clean it properly.now when u will put paper u will listen beep.now sensor is working .fails to pick up mean that fax try to pick paper but not pick the paper .there is a ruler justclean it with cloth and some licquid.and properly check this ruler is movi ng or not moving.
Nov 16, 2007 | Panasonic KX-FL521 Plain Paper Laser Fax
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
HP PSC 2410 All-In-One InkJet Printer Logo
108 people viewed this question
Clive
Clive
