Question about Amana ALG331RAW Gas Dryer
Amana gas dryer buzzes and won't start
I have an Amana gas dryer ( model LG8219W2) that buzzes and fails to start when I try and start it with wet clothes in it. When empty it will buzz a little but will start and run. I pulled the front lower panel off and looked at it when it was trying to start. The belt did turn very slowly and the drum turned as well. It appears that that motor is turning at the same speed. This problem has been getting gradually worse over the last few weeks where before it could run half a load and now it won't run with any clothes in it.
  • Jetmo Mar 22, 2009
    Same here, only the buzzing is coming from the selector switch itself. It will do a load with no problem, but when if you don't wait at least 2 hrs between loads you get the buzzing. I fel its a heat related problem
    Please help we can't afford a new dryer.
    President:
  • 331 Answers
Jeff, what you are describing is a drive motor that is locked up. The only cure for this is to replace the motor. This is probably the most difficult repair to perform on a dryer. You will need to have a lot of patience if you choose to proceed.
I looked up the motor for you, it's a part number 511629P and it lists for ~$145.00. That's alot of clams for a motor! And I presume this unit has some years on it, right? Which means that if you replace the motor, there's a good chance that another component will fail soon.
I'm not trying to dissuade you from a repair, I'm just mentioning possible options. But, if you want an opinion on this, mine would be to replace the dryer. I know this isn't what you wanted to hear, but I hope it helps you decide what to do.
If you choose to repair, write back and I'll do my best to walk you through the procedure.
Posted on Dec 24, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Amana Gas dryer runs but ingniter won't glow and gas valve won't open
That means no power is getting to the gas assembly. The number one suspect would be the fuse which mounts directly on the blower housing right next to the control thermostat.
AMANA MANUAL FOR DRYERS
My Home movies
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2012 | Amana Dryers
I put too many wet items in dryer. I think.. it stopped and won't turn on.. it would buzz when trying to start it, but now won't do that.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 23, 2011 | Kenmore Dryers
Have a five year old Amana Gas Dryer Model Number NDG5805 that makes a buzzing sound only when it is heating, what could be the problem?
the gas valve coils on the gas valve body that hold the gas valve open to supply gas to fire the burner are getting loose and need replacing
Mar 08, 2011 | Amana NDG5805AW Gas Dryer
Model LG8219W2 On initial start up igniter turns on and flame is ok, after heats up and cycles the flame does not reignite,I can see the igniter glow red but flame does not return. the igniter contiues...
HI. This will essentially be an issue that concerns the gas valve coils. With that said, I will post below a complete burner assembly procedure that will help you isolate the culprit. I'm sure that the coils will fail the test, but to be safe, follow the procedure to confirm.
Gas valve/Burner testing procedure:
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Click Here to access a exploded diagram of the burner assembly. The affected coils will be labeled number 15 and 10. The actual coil and valve assembly will be labeled number 11 and the burner will be labeled number 9
Aug 22, 2010 | Amana NED7200TW Electric Dryer
Amana model# lg8219w2 won't heat
need to have a gas line running to it.
Apr 27, 2009 | Amana ALG331RAW Gas Dryer
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Amana Dryer won't start
Depending on your interpretation of the 'buzzing' sound compared to mine, I'd say it may be a relay chattering or the motor trying to start up but the windings are beginning to fail. You may want to clean the motor housing from dust etc and make sure that you do that with the power disconnected. Also: with no clothes in teh dryer..try rotating it around and feel for any spots in that rotation that may be binding.. if the drum has excessive restriction while rotating.. the motor may not have enough torque to overcome that and just buzz,,, Hope that helps...
Aug 14, 2008 | Dryers
Buzzing noise, will not start
Your machine needs a new motor the start switch on the motor has worn out I have tried replacing the sart switch but the result is the same!
Jul 17, 2008 | Amana ALG331RAW Gas Dryer
Amana ALG331RAW Gas Dryer Logo
814 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
