Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Dyson DC15 -
I accidently vacuumed a gummy bear which got stuck where the spinning brushes where and then the brushes stopped spinning and the engine made a straining noise. My husband took of the head and removed the gummy bear. Now the vacuum still works and the brushes do turn but the engine is still making a straining noise. The longer I use the vacuum the louder the noise.
I bought the D15 July 30, 2008
  • 40 Answers
First see this link: http://www.espares.co.uk/datastore/ProductManuals/350256.pdf
There must be something else stuck in the roller assembly. Or it wasn't mounted correct. He will have to dismount it, inspect each piece and carefully reassemble it. Make sure that the wires at the circuit board do not become loose or break.
Posted on Sep 28, 2010
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Tip
    How to remove a sock stuck in the line or brushes
    As soon as you know its happened, stop the unit as the engine may burn out however, in our case we tipped it around, put a coat hanger into various holes on the left of the unit, into the brushes, all done gently and eventually the sock got sucked into the basket. It took some patience but it worked and we just finished the job. Lesson learned, pick up obscure items before you start. This could have been a disaster!! Thanks for the advise and encouragement! Dyson for life!
    on Nov 28, 2013 | Dyson DC15 All Floors - The Ball Bagless...
    Dyson DC23 canister vacuum turbine head attachment stops spinning.
    bearing inside the turbine has failed. cant be repaired you will need to buy a new one your local vac centre will have one
    May 17, 2017 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
    Dyson DC15 brush motor making loud noise
    Hi Wanda, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty with your DC15's cleaner head. It's worth following the steps shown in the Support video attached to help check there is nothing in the cleaner head that could be jamming the brush bar, stopping it from rotating freely.
    If you can't see any obstructions, please give the Dyson customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA), to speak directly with our team of experts.
    Best wishes,
    Jack
    Dyson Online Customer Support
    www.dyson.com
    Oct 28, 2013 | Dyson DC15 Animal Bagless Upright Cyclonic...
    Dyson DC25 Broken Brush Bar Connector
    Hi Alex, it's Jack at Dyson.
    I'm sorry to hear you're having difficulty with your DC25. If the drive spindle of your machine has broken in use, you would need to replace the cleaner head assembly.
    Please get in touch with us directly, as our experts will be able to take some further details to confirm if we're able to replace this for you under the terms of our 5-year warranty. You can reach us by emailing askdysonUS@dyson.com
    Best wishes,
    Jack
    www.dyson.com
    May 19, 2013 | Dyson DC15 All Floors - The Ball Bagless...
    Dyson DC15 beater bar
    I am sorry to hear you are having difficulty with the brush bar on your DC15. It is possible that the brush bar is obstructed. Please visit: http://www.dyson.com/support/help.asp?article=866&product=DC15-SY-STD for step by step instructions on how to locate and remove any blockages from your brush bar.
    However, if this does not resolve the problem a repair may be needed. Please contact us at 1-866-693-9766 US or 0800 298 0298 UK for further assistance.
    Best wishes,
    Jessica
    Mar 18, 2012 | Dyson DC15 All Floors - The Ball Bagless...
    I cleaned out a clog on my dyson and now the brushes will not turn.
    Verify that the belt has not slip off. If the belt is on, remove it and verify that the motor spins when turned on. If it does, clean the belt well from any residue (I use alcohol). Also try to spin the roller with the belt off. If it doesn't spin easily, remove it and clean the sides of the roller. Some have bearing and sometimes gets clogged with hairs and dirt. After cleaning, add some oil to the side of the roller and make sure it spins freely. Hopefully your motor is not damaged.
    Good luck.
    Sep 27, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
    I need a vacuum brush housing assembly for Dyson DC15 animal. Part of it is broken (plastic).
    http://www.espares.co.uk/dyson/dc15/p/1086/716/10
    Try the above link or do a search in google for "Dyson DC15 parts". Also, try searching in Ebay. You should have no problem in locating the part. Lastly, try calling Dyson at 866-MyDyson.
    Good luck.
    Aug 10, 2009 | Dyson DC15 Animal Bagless Upright Cyclonic...
    Brushes are not spinning
    One problem may be that two small wire are broken that control roller functions. See solution with photos at http://bajwa.net/content/dyson-dc15
    Jun 06, 2009 | Dyson DC15 All Floors - The Ball Bagless...
    Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
    260 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
