Question about Bunn NHB Coffee Maker
My coffee pot started peeeeing and so I took it apart and now it's on the table waiting for me to put water in it and then find out how long i'm sopost to wait to turn it on...see I don't know how many cups of water to put in,ty ...raspberry
  • beadroller May 24, 2009
    I pour water in and some runs through the filter basket, but alot runs out a small hole in the bottom of the upper part of the coffee maker onto the counter.
    Novelist:
  • 125 Answers
Hello. Pour water in it, before you turn it on, until water comes back out at the funnel area, then it will be full, and you can now plug it in. If you need more information, go to www.bunnomatic.com, they have alot of information available there.
Hope that helped, and thank you.
Posted on Apr 11, 2009
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try.
1 - put in two pots of water.
2 - put in third pot, the water should start coming out
Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
Feb 27, 2015 | Bunn 10 Cup Home Coffee Brewer
My coffer pot gurgles and it takes 20 min to make a pot of coffee!
I had the same problem with a regular coffee pot. The problem was a large piece of coffee ground that was lodged in the water tube check-valve going to the element. This prevented water from getting to the element quickly enough, and what water did get there mostly turned to steam. We had to remove/replace the tube.
Nov 17, 2012 | KitchenAid KCM511 Coffee Maker
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
I have water draining back into the reservoir. It has been descaled and the needle openings have been cleaned.
Oct 14, 2010 | Keurig B60 Coffee Maker
How do I take apart, and clean my coffee maker?
The only parts that should be removed to clean are the pot and the basket. The remaining parts you just clean with a cloth and hot soapy water (squeezed out) then you clean the inside with 1 part white vinegar and 1 part water. Run a cycle through the pot then run again with just plain water. This do once every 3-4 mos. depending on how often you use your coffee pot. You can actually put them on the top of a dishwasher rack also. You may risk electrical shock if you take it apart.
Oct 09, 2010 | Mr. Coffee FTX49 12-Cup Coffee Maker
Took coffee pot apart in order to clean and cannot get it back to
There might be some ground in the corners where the tray sits.
Mar 12, 2010 | Saeco Vienna De Luxe Espresso Machine
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Takes forever to make a pot of coffee
Decalcify the water holder. Run some CLR and water thru the brew cycle.
Mar 05, 2009 | Krups Caffe Bistro 867 Espresso & Coffee...
Bunn NHB Coffee Maker Logo
296 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
