2003 Kia Sorento Logo
Anonymous Posted on Sep 04, 2012
Getting a 2003 kia sorento to start after hitting a tree and the airbags deploy
It hit a tree and the airbags went off no real damage to the engine but it will not even make a noise when i try to start it and the airbags are deployed could that have something to do with it
A
Anonymous
Diagnosing that problem will require
professional help.
There is no way without the vehicle,
we could even list a bunch of guesses
5 Related Answers
ted dux
  • 135 Answers
  • Posted on Feb 19, 2009
SOURCE: 05 kia spectra airbag not deployed but light is on
Safety-First.
Take to dealer to investigate hidden damage to sensor, etc.
Anonymous
  • 139 Answers
  • Posted on Apr 09, 2009
SOURCE: 2003 kia sorento coolant change
you shoud not have to change it.this wouldbe long life
antifreeze have the PH check at a shop
Anonymous
  • 1489 Answers
  • Posted on May 07, 2009
SOURCE: 2003 Kia Sorento Timing Belt
It's definitely a job for a pro -- dealership or independent garage...
Anonymous
  • Posted on Jun 02, 2009
SOURCE: kia sorento, 2004. clock and airbag warning light
You may have a fuse problem.
Anonymous
  • 474 Answers
  • Posted on Sep 16, 2009
SOURCE: kia sorento diesel engine
could be you have a few bad glow plugs or a relay for them or a bad glow plug controler. the glow plugs are basicly a direct short that creates heat that warms the air in the cylinder to aid initial start.they can be checked wiyh an ohm meter. remove the wire and place one lead on the wire connecter of the plug the other to a good ground.you should have good connectivity. if not replace the plug
1helpful
2answers
Airbags have deployed. Car will not crank
What is the reason for the deployment of the airbags , did you hit the car or they open with no reason. If you hit the car there is fail safe mechanism to stop the engine automatically.
3answers
Where are the airbag sensors located in a 2003 honda accord?
The sensor is usually encased in a pnuematic piston located in the front bumper. You ran over a curb? You hit the bumper, it deployed.
We had two separate accidents involving a deer the airbags never deploy in neither collision. How do i disconnect them?
They didn't deploy cause you hit a deer, the airbags sensors need to get a gforce reading to deploy, hitting a deer ksnt enough to do it
I was just involved in a head on collision with a tree, And i drive a 03 toyota tacoma and im very shocked that the airbags did not deploy,, And i definetly totalled the truck,,any answers would be...
I does not take much to wrinkle the steel. And vehicles are built with impact zones that are designed to crumble in order to absorb an impact.
Also hitting a tree, as long as there was no give, the air bags should deploy if you were doing 15mph+. If you hit a movable object like rear end a car it would be more like 30mph. But is not an exact science either. Say you were doing 30mph when you hit the tree. Did you brake just before impact? The speed would have been reduced by the time you hit the tree.
Then look at how that truck is built. Its a tin can. Its much less sturdy up front because it is a body on a frame. A uni-body would be stronger up front that that Toyota. The bumper is near nothing, not much of a radiator support, weak aprons. They just are not built like a Tonka truck. With all that stuff giving in there may not have been enough energy left to trigger both impact sensors.
There should be at least two sensors. One up front and one inside the cab (the cab sensor may be inside the airbag brain). Both sensors need to be triggered to activate the air bag. Also the impact needs to be from a straight head on to about a 30 degree angle left or right.
I have worked on a lot of Toyota trucks (fleet vehicles/delivery) over the years in the body shop. I have seen how weak they are up front and how easily they will bend.
"Oh what a feeling.....Toyota"
Hi i had an accident with my BMW 320D hitting a tree. On impact the airbags did not inflate. Fortunately my injuries were not serious but the car pretty seriously damaged. Was there a fault with the...
It all depends on the speed you hit tree. BMW can scan computer and track back any faults. Hopefully SRS/check engine light wasn't lit when you were involved in accident.
Side air bag deployed while on the highway. No damage to outside of car. Was driving down highway and the drivers side air deployed. I did not hit anything from what i saw on the outside of car. Has this...
in the U.S. the airbags are programmed to deploy @ 9mph(roughly the same as hitting a kerb hard.)so if the airbag went off you would not know if you hit a pothole, unless you went back to look....dont know any makers airbags that have recalls applied to them.
think of the litigation if there were...........
5helpful
3answers
2answers
When you start your vehicle and the oil pours out
it could be several different reasons for your oil leak but the damage is done id suggest installing a used engine i run a auto repair shop i could probably locate a used engine for you contact me if your interested 704-922-8880
My car will not start!!!
check in the trunk on one of the sides there should be a switch if thats not it check the starter it might have got banged when you went off the road
My 2003 Kia Sorento shakes in the rear after hitting a bump however when you come to a comple stop it stops shaking?
Have look at the tyre if you could see any bulges or have a look at the rim on the edge for any damage
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
