Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Mitsubishi WD-62527 replacement lamp install and brightness low
I recently installed the replacement bulb and the brightness is dim (even at maximum settings). Do i need to clean the bulb, mirror, etc to regain brightness or is there some kind of factory reset that i need to do? Thank you in advance.
  • johnnymacc Mar 18, 2009
    i just replaced lamp in wd-52725 and brightness is dim. windows show bright white lights while screen subjects are dark in the scene. any ideas?
As i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Posted on Mar 20, 2009
  • 3 Answers
I have been having the same issue. Today I tried to tackle the issue and see if I could fix it myself by cleaning various parts of the tv. After I was done even my wife noticed the difference. This is not something for people who are afraid to take things apart.
All you will need is a Phillips screwdriver, some CLEAN compressed air, and a lint free towel meant for cleaning lenses.
First put the tv in an area you can easy get to all sides.
Remove the lamp panel and lamp assembly clean and set aside
Remove the air filter panel clean the filter and set aside. (I cleaned mine with tap water no chemical) I dont recommend using any chemicals anywhere on the tv except to screen the exterior portion of the screen.
Now on the front of the tv gently pry off the speaker grill. Disconnect the front panel data cable.
Remove all the screws under the screen
remove the screws around the screen, 3 on each side and 4 on top.
Gently lift up on the screen while pulling towards you. Rest it somewhere it will not get scratched on either side. Clean the inside portion with a lint free microfiber towel.
Next remove the plastic panel right above the projector lens. This gives you access to the RGB LED's
At this point is where I start going over everything with the compressed air till I dont see any more dust flying around. This is also why I left all the panels off in the back so that I could try to force all the dust out the back of the tv and away from the lenses. I blew air down through the LED's and anywhere I could get air to go.
After there is no more dust use the lint free lenses cleaning cloth to clean the front projection mirror and the projection lenses.
Next take the lens cleaning cloth and use it to clean the lens in the back that focuses the light from the lamp. This part gets very hot and I got ALOT of baked on dust off of the lens. Keep rubbing the lens until all the dust is removed.
Next clean the lamp itself I used compressed air to blow the whole assembly clean and then wiped it down with a microfiber towel.
Next blow out the tv one more time to ensure you get any dust you may have knocked free. Give the lenses all a quick wipe with the lenses cloth and reassemble.
Hope this helps someone.
Posted on Jun 16, 2012
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
Just bought a Mitsubishi WD-52526. With Brightness, Color, Sharpness, Contrast, Everything Video turned all the way up the Screen is still very dim. Is this a lamp issue?
It could be. Do you know if the previous owner ever changed the bulb? If not you may have to replace it. The bulb usually costs around 160ish. I would try it and see if it helps the brightness.
May 04, 2011 | Mitsubishi WD-52525 52" Rear Projection...
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
Screen is dim. Have brightness turned up to max setting. Does the lamp get dim with age? Mitsubishi WD-Y577 dlp rear projection tv
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
Mar 15, 2010 | Mitsubishi WD-Y577 Television
Replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-73727 have new lamp bulb;did not
Your Light Engine needs replaced. Usually around $600.00-$850.00
Jul 11, 2009 | Televison & Video
Only brights work, dimly lit headlamps, no fog lamps
Recheck the bulb number. This happens when the wrong bulb number is installed. Otherwise it could be a bad headlight ground.
May 17, 2009 | 2000 Pontiac Grand Prix
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
1,400 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
