I accidently deleted the wrong photos
You may try steps below to recover pics from sdhc card
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download card recovery software, recommended one is asoftech photo recovery (simply because i was using it and it worked)Memory card recovery software
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
You can retrieve photos by use some software.
As I know, Tenorshare Data Recovery is a great tool that help to retrieve images , recover videos from camcorder , restore photos from samsung galaxy s
I have used it for sd card data recovery few days ago, it really help me, hope it can help you too.
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
I think your camera is not compatible with the SDHC card you bought. Check this: http://panasonic.jp/support/global/cs/sd/connect/dsc/dsc.html
your sd card is sadly corrupted if you downloaded the pictures to your computer your in luck then get a new sd card and download all the pictures from the computer if its a labtop put the sd card on the bottom hope this helped vote thumbs up for more answers hope this helped
-Yashar G.
SOURCE: I DELETED THE PICTURES FROM MY MEMORY CARD BEFORE PRINTING THEM
YES, you have chance to recover the lost photos from your memory card with so-called photo recovery software. Well, since you failed to mention the OS you are running, I'll recommend you have a try of Wondershare Photo Recovery, a program equipped with both Windows and Mac versions. For Windows OS, download here. If you are running Mac OS X, get the program from this link.
Step-to-Step Instruction:
1. Download and install the trial version on your computer, then connect your camera memory card to the computer (I assume you are using Windows). Start Wondershare Photo Recovery and select the drive letter that assigned to camera memory card.
2. Then choose the file type (all, photo, video, music) click "Star Scan".
3. Now the scanning process will start automatically to look for the deleted items. You will then get a list of all recoverable ones.
4. Preview the photos. If your deleted ones are found, then you need pay to get the activation code. And click "Recover".
Tips:
1. Take the free trial version before you buy.
2. Before your deleted items are recovered, do not take more photos or videos.
I hope you good luck. Greetings
SOURCE: deleted photo recovery
This camera photo recovery tool is maybe what you are looking for.
Remember - DO NOT write anything back to your digital camera untill you recover the photos safely. Once the photos are overwritten, it is impossible to recover. Best regards.
