Question about Dell PowerEdge 1400 ( pe1400/210 ) Server
Replace hard drive of my server, now, is not going to startprog m
I'm having problem with my dell poweredge 1400sc. Recently, I received a error message displaying error on my SCHAII. So, I replace the heard drive on it, now, is not going to the Start program mode. I'm getting a black screen.
Call Dell for the best answer. Support is free forever.
If you are out of warranty you will pay for parts.
Posted on Dec 28, 2008
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
How do you make the ide drive primary in the poweredge 1400sc
Master can be single drive on one IDE channel. Or, one master and one slave on a single IDE channel. From there you have the option of expanding over to the secondary IDE channel. Hope this helps.
Feb 13, 2013 | Dell PowerEdge 1400...
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
New hard drive won't go online on our Dell RAID server.
This needs to be reconfigured again. My suggestion is to call DELL again so that things happen they can still able to do the replacement of the hard drive.
Oct 06, 2009 | Dell PowerEdge 1600SC Server
Hi i have a dell poweredge 2850. Orange LED blinking
It sounds like a hard disk has failed or fallen out of sync.
This can be a serious problem if not addressed ASAP.
Call Dell, they have lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis before you call.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Jun 12, 2009 | Dell PowerEdge 2300 Server
Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Jun 10, 2009 | Dell PowerEdge 1800 Server
Dell PowerEdge 1400SC Can not locate hard drives or partition
The controller (probably a RAID controller) that the drives are connected to is one for which Windows does not have the correct drivers. You need to supply the proper driver and .INF files during the initial load. The process used depends on the version of Windows you are installing.
Feb 19, 2009 | Dell PowerEdge 1400...
CAN YOU TELL ME HOW TO GET WINDOWS XP TO LOAD ON THE DELL 2600 POWEREDGE SERVER IT ONLY OFFERS SERVER 2000 AND SERVER 2003 AND I CANT USE EITHER OF THEM THANKS MIKE
Hi tham01,
First off, if the server has raid already setup, you will need to go into lsi logic to format the drives so you can install XP. Once the drives have been initiated from the server bios, just place XP in the CDROM, and shouldn't have a problem loading on the 2600 POWEREDGE SERVER. If your trying to install it with the Dell quick install disk, you can't!!! Install it on it's own without the Dell Disk.
Good Luck!
Mark
Jan 13, 2009 | Computers & Internet
Dell power edge 1600 server
Is this hard drive in a RAID set? if it is, you will need to replace it with the exact same drive. After you do that, you will need to go into the RAID controller bios and initiate a rebuild.
Jan 10, 2009 | Dell PowerEdge 1600...
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Computers & Internet Logo
333 people viewed this question
Alun Cox
