Hi ,
i bought GE refrigerator 2years ago.
model no is: GSH25JSRF
Suddenly one day water flow is stopped from the dispenser.
I changed the filter, still no use.
What is the solution.
Hope u guys reply me.
Thanks.
Kris.
refrigerator does not dispense water, i agree that it could be water line frozen. i turned off freezer side for half hour , what else can i do
-   I have the same problem, but I did diagnose it a bit further. I also replaced the main board this summer, but I don't think this has anything to do with it. The water tube runs into the door at the bottom of the refrigerator. There is a quick disconnect there. I can disconnect the hose and press the water activation lever and water will come out. What this tells me is that there is a blockage inside the door somewhere. I have tried to blow air through it using an air tank and got nowhere. I am trying to locate a diagram for the hose inside of the door...
-   mxr13
Jan 16, 2009
-   we are just experiencing the same exact problem at around the exact same time. our fridge is about the same age. we just tried a new filter and did't help.
i also notice that the filter DOES fill with water, so the problem must lie between that and the water dispenser.
we also had to replace our main board this past summer. when i push the water button i can hear it running. also, ice comes out the dispenser, but it appears fridge is not making any ice-   Guest
Dec 23, 2008
-   i have a gss25jepebb 3 days ago water stop coming from the despesnser could it be my water lin is frozen-   bradleydalla
I had a simular problem! I tried multiple things to make it work!
- bought new filter
- open back of the fridge... (dual outlet water valve)
Finally, I went to a different forum and found a unique idea.
First at the very bottom of the fridge theres a cover remove the cover and you should see the water hose running to the door from the back. In the middle of the hose there a coupler where the hose was spliced by the manufactuer. Now this valve once you separate it will not work correctly, unless you buy a new coupler (4$)... I'm el cheapo, I bought teflon tape for 50 cents (from previous project)... Wrapped around about half dozen times and made sure it wasnt leaking...
Secondly, when you disconnect the coupler no water should shoot out, until you press the water dispenser arm. If water shoots out of the hose on the bottom then you problem is really, really, really easy. You have simplely ice/ or another item blocking water hose to the actual dispenser.
I turned off the frezzer left the door open for an hour or so. I also used my wife's blow dryer on hot, and put it where the ice comes out of the ice maker. I would press the arm peridocially to see if the ice blockage melted yet. REMEMBER: door must be closed for pressure to push on the ice blockage. Thinking back, I might have been finished sooner... I was thinking the water dispenser would work with the door open.
If this doesnt work, then you have other problems... Bad water dispenser selonoid (you can hear this little motor turning even without water), dual water outlet valve maybe broken... Going outside my knowldege level at this point.... But i guess you computer board maybe going bad. Not sure if this computer has anything to do with water dispensing....
Hope this helps! My wife left me alone for about a day or two while she enjoyed the water dispenser...And she broke the vaccum.
My kitchenaid (kscs25stss01) icemaker is no longer working after turning icemaker off. Icemaker has...
(More)
My kitchenaid (kscs25stss01) icemaker is no longer working after turning icemaker off. Icemaker has been back on for the last week or two but no ice has been produced. After reading solutions I decided to check the water inlet tube for ice, but I cannot figure out how to check it. Do you have any suggestions? Thanks.
The ice maker works fine. But the door ice dispenser will only dispense crushed ice. It will not...
(More)
The ice maker works fine. But the door ice dispenser will only dispense crushed ice. It will not dispense cubed ice. (The buttons seem to work.) Also, when it does dispense crushed ice, the ice is cast all over the place. A significant portion of it ends up on the floor.
Thanks.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
