Question about Frigidaire ATF6000ES Front Load Washer
Remoive the top/frgidaire ftfb4000fs1
How do i get the top of this model off so i can replace the plastic grommlet, water hose hook-up. It froze and cracked.
  • 32 Answers
Under the top lip on the rear of the unit there are three screws securing the top to the cabinet. Remove them then stand in front of the unit grab both sides of the top and slide back. voila
Posted on Dec 23, 2008
I have a Whirlpool water heater, the drain valve is plastic and has split into at the hose connection, I want to replace the plastic with a brass valve. How do I drain the water?
Most water heaters have a drain on the bottom where you can hook up a garden hose and run out side. Or you can get an air compressor and hook the air line to an open hot tap and put pressure and run the water out another hot tap. Close all taps but these two and make sure the cold water inlet to the tank is shut off.
Jun 26, 2017 | Whirlpool Water Heaters
Ice maker not getting water to it, I recently replaced the copper line from the wall to the refrig with a flexible stainless steel. The refrig stayed disconnected for a week before replacement now I...
Hello DeWayne,
That hose that connects to where the water comes out as it cycles,the end of it where it goes to the top and enters into the freezer/icemaker is frozen and needs to be removed and thawed,you could take that hose off at the water valve and blow through it if you can not blow through it easily its defiently froze,if once you thaw it it becomes froze again within a couple days up to a couple weeks the water valve where that hose connects to at the bottom is bad and causing it to freeze and that valve should be replaced.
I hope this will help you to get your icemaker working,
Gene
Aug 08, 2011 | Frigidaire FRS3R5EMB Side by Side...
How do i replace the water level switch on a kenmore 70
The water level switch is located in the console, usually with a clear plastic tube going to it. You need to make sure the hose is not plugged. The system plugs easily if too much soap gets used... there is a collector that this hose hooks to near the bottom of the side of the tub. It is the connnection that plugs...just check it....
Mar 08, 2011 | Kenmore 24032\24036 Top Load Washer
There is no water flowing to my ice maker but i do have water for drinking flowing
Check back behind the icemaker there is a plastic tube make sure is is not froze up...Observe the back of fridge there is a water line that goes from the water valve to the tube near the top check that it is attached and in good condition... There are 2 more things to check, the water valve, as the icemaker side may not be functioning... The next would be the ice-maker unit may have failed and not be powering the water valve as needed... If you can hook up a test cord to the valve and it works replace the icemaker unit... If the valve does not work replace the valve.
If I can help with anything else please let me know.
Apr 07, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My washing machine will not fill up with water. The water is running into the machine but never fills the machine. It seems like it is just running directly out again. I own a frigidaire top loading...
The drain hose must be higher than the tub. Had the drain hose at any point been lowered or dropped in such a way that it would be below the tub?
Dec 22, 2009 | Washing Machines
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How do I replace the water pump?
replacing pump,,theres two screws on either side of console..phillps head remove end console caps if equipted,,with hand..if earlier mobel there right behind console..flip console back dont remove..disconnect lid switch,,the small harness that has the brown and gray ,,wires with a green groun,,always unplug unit first...remove 2 brass clips on booth ends,,now just pull the cabnit toward you and leave on side,,look straight down at your feet theres your pump,,the plastic part with the 2 hose leading out it..pry punp clips up with a smal screw driver,,twist a little and there off,,remove drain hose,,and tub to pump hose ..reverse to put together
Dec 27, 2008 | Kenmore 22422 Top Load Washer
Ice maker
Disconnect the plastic hose at the top of the refer (the one coming from the water valve) and set the end into a glass. After about two hours you should have water in the glass. If you have water in the glass then the spout that is inside the freezer is froze up and needs to be thawed out (use a blowdryer), If there is no water then it will be the valve or ice maker.
If it is froze up, adjust the cold controls back to the middle settings, you may have it to cold in your freezer.
Jan 18, 2008 | Frigidaire FRT17G4B Top Freezer...
Back reservoir
Kiwy, your part number for this reservour is 4838jj1003a. Since they had a lot of problems with this tank they replaced it with coiled plastic tubing. You can find the replacement part at repairclinic.com, it will show you a picture of it. Or you can go down to your local hardware store, buy some 1/4 inch plastic tubing for water and 2 quarter inch John guest fittings to hook it up. That's all it is now, is coiled plastic tubing to chill the water. Catriver.
Dec 28, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
Fridge is leaking
Your plastic line which carries water to the dispenser has a crack in it.  Activate the dispenser and have another person pinpoint the lead and splice two pieces together with plastic connector.
Oct 15, 2007 | Amana ACD2232HR Side by Side Refrigerator
Frigidaire ATF6000ES Front Load Washer Logo
103 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
