Question about Zenith IQB60M92W 60" Rear Projection Television
Blue Bands on sides of Zenith Projection TV D60WLCD
There are blue bands on both sides of the TV. Narrower at top - 2", the band gets wider toward the bottom.
    Problem Solver:
  • 8 Answers
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Posted on Aug 02, 2009
My tv zenith is working the only ploblemb is the escreen get blue you see evryting blue de color of the people too
Your problem sounds like the projection bulb is going bad. It is the main problem with projection TV's, and is usually very spendy. I would recommend calling Zenith and request a new bulb.
May 03, 2011 | Zenith D60WLCD 60" Rear Projection...
My hitachi keeps showing red and blue bands. when
Replace your convergence ICs they are big black ICs will have part number on them STK392-110s use 150s better ICs Mats has them 1-800-628-1118 also CK Low ohm reisitors 1.5ohms and up 3.9 ohms
May 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Blue escreen
Call LG they bought zenith and there is a class action suit so you can get a replacement or repair refund from LG
Jan 15, 2010 | Zenith D60WLCD 60" Rear Projection...
Hitachi 51GWX20B Rear projection HD tv, convergenance/color issue
I bet you have a open resistor for the blue sub yoke. Typically it would be a 2.2 omh or a 1.5 ohm. Some times it is hard to tell buy looking at them. It you have a Ohm Meter, unplug the set, pull the sub yoke plugs from there connectors.(They are the plugs right behind the heat-sinks) . If you know the resister color code it will be a must to determin if any are open or increased in value. If you see a resister that has two red bands and two gold bands, it it a 2.2 ohm. A resister with a brown band, green band, and two gold bands is a 1.5 ohm. On some occasions, you will see a brown band, a white band and two gold bands, this is a 1.8 ohm. This circuit does not give much leeway for subing with wrong values and it even could cause premature failure if the IC's again. One last thing, double check that all the pins made it through the board when mounting and are not touching each other top side of board. As far as the one side of the picture pulling in , I think it is all related. I have seen defective STK392-150's new out of the bag.
Well thats all I can tell you at this point.
Good Luck,
Skyassoc
Jun 19, 2009 | Hitachi 57SWX20B 57" Rear Projection...
COLOUR ON MY TV IS MESSED UP.
palsonic tv is green and blue
Jan 11, 2009 | Televison & Video
LCD TV Fault
Pull back OFF look for bad capacitors if they are puffed up on top they are bad so replace them at same (UF) the voltage can be higher .for example if it is 220uf it has to be 220uf ,if 25volts it can be 35v.
Jan 10, 2009 | Televison & Video
Samsung HL-R4667 DLP There are about 6 vertical bands (usually all the same color) running top-to-bottom and within these vertical bands is a picture trying to come in. The screen behind the bands is...
needs a DM Board, prity easy to change yourself, if you order one, make sure you give them the version number off the Right side of the TV, will be somthing like SP01, To change - when you take the back off the tv, it will be on the left hand side, have to unplug 3 or 4 connectors, then take the plastic covering off, and it will slide out.
Jan 08, 2009 | Samsung HL-R4667W Rear Projection...
Zenith D60WLCD Repair
Sep 21, 2008 | Zenith D60WLCD 60" Rear Projection...
Zenith D60WLCD 60 in. Rear Projection
CALL ZENITH AND PROVIDE SERIAL NUMBER AND PROOF OF PURCHASE. THEY WILL SEND TECH OUT TO FIX OR REPLACE TV. THIS IS A PROBLEM WITH MANY PROJECTION TV'S BECAUSE OF A FAULTY PART.
Oct 03, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith blue corners
Sep 02, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith IQB60M92W 60" Rear Projection Television Logo
134 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
