Question about Nintendo Wii Console
My remote wont work at all
My wii wont pick up any of my remotes signals
  • Anonymous Feb 01, 2009
    my Wii remote will blink but that is it. It worked fine last night.
  • 34 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
My Wii remote wont work how do i reset it?
  1. How to Reset Your Wii Remote
    • 1 First you will need to check a few things, just to make sure what the actual problem is.
      *Check to see that all cords are properly plugged in.
      *Make sure the sensor bar is properly center above or below your tv set.
      *Make sure that nothing is blocking the signal to the sensor bar.
      *Make sure that the batteries in the remote are in good working order.
      *Make sure that there are no wireless devices close by that might be interfering with the signal.
    • 2 If after all this the remote is still not working then it probably needs to be re-synced.
    • 3 Turn off and unplug your wii console for a few minutes.
    • 4 *Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
      * Then remove the battery cover from the wii remote, inside you will see another red button.
      * Press and release the red button, the blue lights on the remote will start blinking.
      * Quickly press and release the red sync button on the wii console.
      * The remote will stop blinking and it should now be synced.
or visit the links below
Read more: How to Reset Your Wii Remote ' eHow.com http://www.ehow.com/how_4527749_reset-wii-remote.html#ixzz1OyHyruvP
if you think this help you please rate me by that it will help me to... thank you in advance...
Jun 11, 2011 | Nintendo Wii Console
My wii wirless sencor bar has a blue light on but wont pick up my wii remote
Perform a remote power requirements check. For example, check for batteries in remote control compartments, replace with fresh new batteries for desired operations. Alternatively, the remote control would require power on buttons before functioning with NIntendo. Locate controls power button to initatiate process.
Jan 11, 2011 | Nintendo Mini Wireless Sensor Bar for Wii
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
Cant use the remote
The remote has to be sync'd with the wii properly. If you sync it with another wii you have to sync it back.
Open the battery cover on the wii remote.
Open the front cover door in the middle front.
In each you will see a Red circle sync button in the remote and a rectangle button above the memory slot on the wii front.
Turn on wii, press the sync button on front of wii, then press sync button on remote, the remote should then get a signal and blue lights on front show player #. If not, turn off and try again. Once sync'd it will work with that Wii.
May 09, 2010 | Nintendo Wii Console
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Wii not picking up signal from wii remotes even though sensor bar is in the right position andn wii remotes are synched to the console.
are you having this problem at the wii menu or during game or the hbc?
some games only allow for a certain amount of wiimotes to connect to the system (usually 1 or 2)
if it has a problem with the hbc (HOMEBREW CHANNEL) then some programs only allow gamecube controllers to work.
Jul 06, 2009 | Nintendo Wii Console
2nd remote problem with certain games
take the battery cover off the wii controller and press the red button. then open the cover at the front of the wii and press the red button. do this when you are at the wii menu. this registeres the remote
Dec 26, 2008 | InterAct Accessories Speed Racer: The...
My wii remote
@ Slivic22
Some games does not use Sensor Bar pointing because they play with motion/accelerometer only. After you select the number of sets on Wii Sports Tennis, there is no Sensor Bar pointing except for Pause menu. That's because you Swing the remote like a racket.
May 24, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
93 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
